10-24-2023, 02:54 PM | #1 |
electic pump
Can anyone recommend a good brand 6 volt flow through electric fuel pump? thanks
10-24-2023, 04:56 PM | #2 |
Re: electic pump
Prior post:
https://www.fordbarn.com/forum/showt...ight=fuel+pump Pump: https://www.amazon.com/AUTOKAY-Elect...s%2C122&sr=8-3 Last edited by Merc Cruzer; 10-25-2023 at 06:04 AM. |
10-24-2023, 08:47 PM | #3 |
Re: electic pump
Thanks for the help.
11-14-2023, 01:09 PM | #4 |
Re: electic pump
I saw a discussion about this on the ACAA forum a little while ago, but I can't find my notes. They provided model numbers for a couple of flow through fuel pumps -- maybe you can find the thread -- it was for Buicks but of course these pumps work on any old car and come in 6 and 12-volt models. The poster suggested that before installing, in order to make sure it's a "flow through" pump that you suck and/or blow at each end to see if you can blow through it and also pull through it without a problem. Good luck.
11-14-2023, 05:27 PM | #5 |
Re: electic pump
Senior Member Join Date: May 2010 Location: Florida and Penna. Posts: 4,471 Default Re: Airtex fuel pumps Quote: Originally Posted by Johnnydidd View Post "Help me understand? I have an electric 12v holly fuel pump only. If I put a mechanical pump in series will it pull through the electric pump shut off, if not how do I plumb around the electric pump shut off so I can use it for backup?" If you can blow through the electric pump from the tank end with your mouth the mechanical pump will pull gas through the electric pump. If the electric pump has a check valve in it you can blow from the tank side but not from the engine side. With a lite check valve you can blow through from the tank side with your mouth the mechanical will pull through that also. G.M. __________________ www.fordcollector.com Prior posts: https://www.fordbarn.com/forum/showt...tric+fuel+pump https://www.fordbarn.com/forum/showt...tric+fuel+pump https://www.fordbarn.com/forum/showt...tric+fuel+pump Last edited by Merc Cruzer; 11-16-2023 at 10:44 AM. |
