03-25-2021, 07:24 PM | #21 |
Re: Posting pics?
Glenn, just a couple little tips.
I got some clear plastic (very thin) and made a gasket for each base, that I cut to just a hair bigger than the base, so you could barely see it but at least helped cushion the base on the paint. I also drilled the mirror stud holes so the vertical glass run was centered between the 2 mirror mounting studs. Then I still had to get my wife with her thin arms and little hands to get up in there to start the nuts with (built in washers) started onto the studs... easy peasy Good luck with yours. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
03-25-2021, 07:42 PM | #22 |
Re: Posting pics?
Very nice Ride! Looks like it needs nothing!!! Enjoy it!
Nomad |
