07-04-2013, 04:40 PM | #1 |
Cabriolet/Coupe/Sport Coupe Fixed seat backrest upholstery
I'm putting on the cover (Le Baron Bonney) on the seat backrest of my fixed-seat Cabriolet. Although the material is different I believe that the backrest is built and upholstered the same way on fixed seat coupes and sport coupes.
The instructions from LB-B are not complete, so it is not easy to know exactly how it should be done. I have got it reasonably OK, but far from perfect, so the question is, am I doing it right ? The main questions are : - At the side ends I have hog ringed the backing fabric to the spring pack. (see first photo) The top cover fabric is only tied in with the elastic draw string that LB-B put in. Is this the correct way to secure the side edges of the top cover fabric. -Also, at the bottom of the sides, (first photo) how should the material be finished off. (see arrow) - In the second photo, where the material is tacked around the top corners, the material piles up. Should the material be folded in a dart at this point ? Any other suggestions or, best of the best, could anyone post a photo of how an original or correctly restored fixed seat backrest is upholstered ? |
07-05-2013, 01:39 AM | #2 |
Re: Cabriolet/Coupe/Sport Coupe Fixed seat backrest upholstery
If it is of any help, the rear seat back on my Tudor has cord ties to a tack on the top corners to pull the creases out.
You will have to strenghen that join on the first pic., maybe also with a cord sown in ? |
07-08-2013, 12:11 PM | #3 |
You might get some help from the Le Baron Bonney web site. If I remember correctly, they have a video showing how to do a front seat. Ed
07-08-2013, 12:31 PM | #4 |
LeBaron Bonney has a video on doing a Backrest at their web site.
http://www.lebaronbonney.com/instructions.htm
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
07-14-2013, 09:21 PM | #5 |
any updates or additional helpful hints from anyone? I am not too far from needing all the help I can get for my 68A seats. |
