03-24-2021, 06:38 PM | #1 |
Posting pics?
I've searched around on here but can't find an answer. How do you post pics without knowing the the url or whatever it is?
A Proud Navy Veteran |
03-24-2021, 06:43 PM | #2 | |
Re: Posting pics?
https://www.fordbarn.com/forum/showt...ighlight=photo https://www.fordbarn.com/forum/showt...ght=post+photo There are a number of other threads on this, comes up often. Last edited by JSeery; 03-24-2021 at 06:53 PM. |
03-24-2021, 07:02 PM | #3 |
Re: Posting pics?
Thanks, but HOLY COW!!
03-24-2021, 07:13 PM | #4 |
Re: Posting pics?
Not sure what the holy cow is, it is fairly simple to post photos, just takes some explaining if you don't understand it. A couple of clicks and it's posted. Basically select a photo, upload it in the popup window and then post it.
03-24-2021, 07:32 PM | #5 |
Re: Posting pics?
As JSeery says above, it really is a lot simpler to post pictures (once you get used to it) than the written procedures make it sound like. It usually takes me roughly 4-5 seconds to post a picture. I don't even have to think about it any more....it just HAPPENS! DD |
03-24-2021, 07:58 PM | #6 |
Re: Posting pics?
A Proud Navy Veteran Last edited by o2bnkc; 03-24-2021 at 07:59 PM. Reason: Hey, it worked!!! |
03-24-2021, 08:04 PM | #7 | |
Re: Posting pics?
03-24-2021, 09:36 PM | #8 | |
Re: Posting pics?
03-24-2021, 09:40 PM | #9 | |
Re: Posting pics?
Your convert looks very nice, I like the color combo on it... One bad thing about them is the cowl mirrors, you can't see behind you very good, especially out the right cowl mirror. Hinge mirrors are better. I put the cowl mirrors on each of my doors, where the vent windows will still open. Below is a picture of each mirror, look in them and you can see behind. Click on pictures to Enlarge
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN Last edited by Lanny; 03-24-2021 at 09:56 PM. |
03-25-2021, 09:37 AM | #10 |
Re: Posting pics?
03-25-2021, 11:29 AM | #11 | |
Re: Posting pics?
03-24-2021, 08:05 PM | #12 |
Re: Posting pics?
Nice car! I like Folkstone Grey on the '40. Maroon complements it well.
I put lots of miles on this one over 20 years. |
03-24-2021, 09:06 PM | #13 |
Re: Posting pics?
Very nice!
03-24-2021, 11:17 PM | #14 |
Re: Posting pics?
03-25-2021, 05:50 AM | #15 |
Re: Posting pics?
And without the giant front tires
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 03-25-2021 at 11:04 AM. |
03-24-2021, 08:07 PM | #16 |
Re: Posting pics?
petehoovie's trick is to use the image URL (right click a picture and copy link) then use bracket IMG bracket, paste the link then bracket /IMG bracket and any linked internet picture can be full size on our message boards.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
03-25-2021, 10:06 AM | #17 |
Re: Posting pics?
Glenn,
I have always been afraid of opening up a can of worms once you start removing door hinge pins. There's got to be a better way. A tiny unobtrusive "wireless" rear view camera would be wonderful. |
03-25-2021, 10:22 AM | #18 |
Re: Posting pics?
Hi 19Fordy,
I have a set of the pin mounted mirrors but took them off a long time ago. I didn't really care for them and am not about to remove the hinge pin after my latest paint job on the 40. Lanny has mounted the cowl mount type to the doors. Glenn |
03-25-2021, 01:20 PM | #19 |
Re: Posting pics?
Thanks Lanny!
I can see your mounting well now and may give it a go. I don't mind when I have the top down, which is most of the summertime but in Fall with top up I have to ask my passenger wife to check for me. I had one passenger's vent window from that had two sheared off screws, high up on the frame where I figured that a peep mirror had been installed at one time. The peep mirrors are too small though and except for drilling into the door, your solution looks great. Thanks, Glenn |
03-25-2021, 07:24 PM | #20 |
Re: Posting pics?
Glenn, just a couple little tips.
I got some clear plastic (very thin) and made a gasket for each base, that I cut to just a hair bigger than the base, so you could barely see it but at least helped cushion the base on the paint. I also drilled the mirror stud holes so the vertical glass run was centered between the 2 mirror mounting studs. Then I still had to get my wife with her thin arms and little hands to get up in there to start the nuts with (built in washers) started onto the studs... easy peasy Good luck with yours. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
