Old 06-24-2020, 05:05 AM   #1
30-9
Default Helmet distro gaskets
Hi Gents
Aside from moisture can a helmet run without gaskets? Or will the distro (inner cap) be too close to rotor?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 06-24-2020, 09:20 AM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: Helmet distro gaskets
A helmet could run w/o gaskets, but why would you want to??
The inner caps do not have a gasket where they locate in housing that would affect contact spacing. The gasket that locates between inner and outer caps also seals inner caps at housing.
John
Old 06-24-2020, 09:23 AM   #3
30-9
TY Sir!
Thanks - 30-9
1939, 1940
Old 06-24-2020, 04:02 PM   #4
Lawrie
Lawrie's Avatar
I ran our 33 for 30 miles in the worst rain ever last week ,it never missed a beat, I bet it would have with no gaskets in the distributor.
When we first had the 33 it had a remote coil setup, and no gaskets, you only had to wash the tail light and it would,t start.
Lawrie
Lawrie is offline   Reply With Quote
Old 06-24-2020, 04:16 PM   #5
30-9
Lawrie
It maybe you Aussi slang or my age.
Are you stating that no gasket worked out well for you?
Thanks - 30-9
1939, 1940
Old 06-25-2020, 05:40 AM   #6
flatmotor40
flatmotor40's Avatar
That is the way my 40 does wash any part and moisture gets in cap.Winter time cool air from fan causes the cap to condense up so i carry a spare cap in glove box.Gasket or not.I do have a Mallory electronic dist in my 59a.When i wash the car i take the cap off for a day or so.Keep WD40 in it also
flatmotor40 is offline   Reply With Quote
Old 06-26-2020, 04:59 AM   #7
Lawrie
Lawrie's Avatar
Fixed it ,left out the NO.
Lawrie
