Old 06-18-2020, 10:28 PM   #1
Rocket455
Default 1950 Rearend Disassembly
Slowly getting back to work so the progress on the project is slowing down. This whole COVID thing made me realize how much work gets in the way of me doing things I want to do.
Anyway, I tried taking apart the rearend. I removed the 10 nuts from around the differential thingy. I don't know if this is called a pumpkin, a 3rd member, differential cover. Whatever the hell it is I can get it maybe 1/2" or so separated from the housing. I can't get it to clear the studs. Is there something else holding this thing together? Or am I just not using enough force. I didn't want ruin anything so I left it.
Do I need to remove the giant nut from the yoke to get this thing apart?
To be clear this is a 1950 Coupe. Original overdrive car. I don't know if this is a dana 41 or 44. Apparently they both came in 50 cars. But I believe it to be original.
Rocket455 is offline   Reply With Quote
Old 06-18-2020, 10:57 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 1950 Rearend Disassembly
Did you remove the two axle thingies first? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-19-2020, 12:11 AM   #3
cas3
yup, those thingys gotta come out first!
Old 06-19-2020, 02:48 AM   #4
Rocket455
Yes. Axles were completely out. But the thingy still won’t come all the way off. Gets hung up around 1/2” off the surface of the housing.
File Type: jpg 19428C67-4C30-4C34-A6D0-7090C97A8806.jpg (41.2 KB, 55 views)
Old 06-19-2020, 03:01 AM   #5
Mart
Mart's Avatar
Can't think of anything that would stop it coming out. As you approach the area where it gets hung up, wobble it about. Try and deduce where it is catching. As long as the axles are out of the way it should come out.
Mart.
Old 06-19-2020, 03:31 AM   #6
flatheadmurre
flatheadmurre's Avatar
That axle doesn´t look like it belonged in that car from start...just saying when you start hunting for parts...
Dana 41/44 has a lid on the back and not a removable pumpkin...
Old 06-19-2020, 06:03 AM   #7
Ken Henry
Ken Henry's Avatar
It looks like the correct car axle to me. Not sure why it’s not covered in gear oil though? Do you have the shop manual?
Ken Henry is offline   Reply With Quote
Old 06-19-2020, 06:53 AM   #8
flatford8
flatford8's Avatar
When I took mine out of my ‘51, I used two small pry bars and pried at opposite sides, (3-9, 6-12) gently. It fits tight over the studs. As long as the axles are out there should be nothing holding it in....... Mark
PS...A manual is a big help.
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 06-19-2020, 07:50 AM   #9
richard crow
flatford8 has it right just make sure there are not some of those copper washeres on the studs
richard crow is offline   Reply With Quote
Old 06-19-2020, 09:04 AM   #10
rotorwrench
rotorwrench's Avatar
Studs can get enough bend or deflection angle to them that they make it hard to remove housings like your third member. I don't know why they didn't just use bolts. These old units were the father of the 9-inch axles. By the time it came out in 1957, Ford had learned more about how to make them.
The side bearings are held with an adjustable retainer if I remember correctly. I've never seen one back out since they are usually locked but a person should be able to see them through the axle tubes. I don't know if they can even come out far enough to block removal. There is nothing else in there that could lock anything up.
Old 06-19-2020, 10:47 AM   #11
Rocket455
Thanks, everyone. I do have the green shop manual but I couldn’t really make sense of this part and the diagram didn’t give me confidence.
If nothing else could be holding it up then I’ll get it out now.
Old 06-19-2020, 06:23 PM   #12
flatford8
flatford8's Avatar
As your prying it up, try to see if any one stud is bent, binding in the hole. If you see one, let the center section ( pumpkin) back down, put on a nut till it’s flush on the stud then tap it with a hammer till it’s centered in the hole......Mark
Billy Joe Shaver
Old 06-19-2020, 07:39 PM   #13
joe 1950
joe 1950's Avatar
why are you taking it apart did it explode inside or are you just going to clean and inspect it i had to take mine out of my 50 cpe because it ate the spider gears but like was said pull axles out make sure you pull them at least 5 inches out remove nuts and with little prying should walk right out good luck
joe 1950 is offline   Reply With Quote
Old 06-19-2020, 07:44 PM   #14
paul2748
paul2748's Avatar
Only the wagons and sedan deliveries used the Dana. All the rest of the sedans used the pumpkin type rear.
48 Ford Conv
56 Tbird
54 Ford Victoria
Thread Tools
Display Modes
