Old 08-15-2019, 07:42 AM   #1
oldskool
oldskool's Avatar
Default spark plugs 59ab
what is a good plug for a 59ab edelbrock heads, tube headers, dual holley carbs
oldskool is offline   Reply With Quote
Old 08-15-2019, 08:35 AM   #2
big job
big job's Avatar
Default Re: spark plugs 59ab
Motorcraft works for me don't know the number ask Napa
big job is offline   Reply With Quote
Old 08-15-2019, 08:59 AM   #3
tubman
tubman's Avatar
Asking NAPA might not be a good thing to do, because they will probably give you the number of a stock replacement, that will probably be incorrect. Make sure you have the proper thread length. Many aftermarket heads take longer than stock plugs. Stock heads take 3/8" reach plugs (Champion H series), while most after market heads I have seen use 3/4" reach plugs ("L" series Champion plugs). Too short a plug will be "shrouded", while one that is too long will interfere with the exhaust valve, causing a collapsed side electrode at best and engine damage at worst.
Perhaps someone on here has a more precise answer, but the make of plug is a personal choice, the length can be determined by screwing one into a head that's off the engine, but the heat range is best determined by experience. Edmunds heads have the spark plugs relocated so they can use extended tip plugs, but I think they are the only ones that can. resistor plugs are usually unnecessary, and the other variables are again, personal choice.
Old 08-15-2019, 03:41 PM   #4
alanwoodieman
autolite 216 and forget the TMK
alanwoodieman is offline   Reply With Quote
Old 08-15-2019, 05:02 PM   #5
john in illinois
john in illinois's Avatar
Edelbrock recomends rc12yc or rc14yc champions or equvalent. 14mm, 3/4” reach,flat gasket,5/8 hex extended nose. I like NGK plugs,but others work fine.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 08-15-2019, 07:34 PM   #6
clo
NGK pn# b-4L
clo is offline   Reply With Quote
Old 08-16-2019, 09:26 AM   #7
john in illinois
Originally Posted by clo View Post
NGK pn# b-4L
This number is wrong. Only 3/8” reach, need 3/4” For Edelbrock modern heads per the Edelbrock instruction sheet.
Autolite 3924 or Ngk BCP5ES interchange amoung others.
John
File Type: jpg 96D04078-6D37-4DA4-AC92-5D1EB01BC777.jpg (57.8 KB, 24 views)
File Type: jpg 7A4AD330-09B7-444D-A558-C303530DF3DB.jpg (73.5 KB, 15 views)
Welcome each day
Old 08-16-2019, 09:38 AM   #8
PeterC
PeterC's Avatar
Just for comparison - I run NGK- B-4L for my 59ab - Navarro heads, Fenton cast headers and dual Stromberg 48's.
PeterC is offline   Reply With Quote
Old 08-16-2019, 10:21 AM   #9
Tim Ayers
Do what you want, but I wouldn't use Champions. Quality is way down from their glory days.
Old 08-16-2019, 11:00 AM   #10
tubman
tubman's Avatar
To be clear, I wasn't recommending Champions, I was just using them as an example, because they were used by Ford in those days. As I said, brand is a matter of personal choice. That being said, I have a set of Champion L82YC plugs in the Edmunds heads on my '51 Merc and they have performed admirably.
Old 08-16-2019, 03:22 PM   #11
Graeme / New Zealand
Graeme / New Zealand's Avatar
Ngk b6l
gb
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
