07-19-2017, 12:30 PM | #1 |
41 Ford front lower half fender inner center reinforced
Please see this pic I want to remove it but see no signs of it being welded in place. Again this is the lower half fender inner support that is dead center with the wheel.
07-20-2017, 07:04 AM | #2 |
Re: 41 Ford front lower half fender inner center reinforced
Not exactly sure what you are asking but I'll see if I can post a picture of my wheel area later.
07-20-2017, 07:14 AM | #3 |
I will also attach a pic having a bit of trouble. But on the lower half of the front fenders there is a added piece of steel fitted in to strenghten the narrowest part of the fender directly above the wheel. Need to get it out to repair some rot. trength
07-20-2017, 07:16 AM | #4 |
Pic I hope one last try
07-20-2017, 12:14 PM | #5 |
On my 41 there is a panel bolted behind the wheel, like a water deflector or rock shield. there is nothing above the wheel. Can;t really tell from your pic. what you have. Al
07-20-2017, 04:29 PM | #6 |
07-20-2017, 06:02 PM | #7 |
They are only two pieces upper and lower and decided today not to fix or sandblast just keep a good set for myself and get rid of the rest. Thk you anyways
Bob |
07-20-2017, 10:44 PM | #8 |
mine has same reinforcement. assume it is spot welded in place
07-21-2017, 09:02 PM | #9 |
'41 i used to have had those reinforcements, seemed to be factory. i think they were needed because that spot was so narrow.
Thread Tools | |
Display Modes | |
