Old 01-23-2018, 05:09 PM   #1
cbillelder
Default Do You Have A Chassis Engineering Mustang II Front Kit You Haven't Installed Yet?
Hi Guys-
I'm looking for some help here. I have a Mustang II front crossmember made by Chassis Engineering that I want to install in my '36 Ford frame. Unfortunately, the rear brackets for the lower arm strut rods were lost, so I'm going to have to make them since Chassis Engineering is out of business. I have another '36 Ford here with that setup that I can get most of the measurements from, but I need to know what the hole size is in the brackets that the strut rod rubber bushings mount thru. If you have one of these kits you haven't installed yet, could you measure the diameter of that rubber bushing hole for me? I would appreciate it very much. It doesn't matter what car your kit is made for. As long as it's a Chassis Engineering kit, I'm sure the bushing holes are all the same size. If not, do you know someone who has one? Please let me know if you do. PM me or email me at [email protected]
Thanks guys,
Bill
cbillelder is offline   Reply With Quote
Old 01-23-2018, 05:59 PM   #2
Ggmac
Default Re: Do You Have A Chassis Engineering Mustang II Front Kit You Haven't Installed Yet?
I no longer have the car but have installed a few . Go to speedway and look at there tubular lower control arms ( don't require a strut and look cleaner ) or use the tubular lower strut set up . Pg 28,28,31 of current Street Catalog .
Ggmac is online now   Reply With Quote
Old 01-23-2018, 06:42 PM   #3
fortyfords
fortyfords's Avatar
Chassis Engineering has been bought so you should still be able to get parts.
fortyfords is offline   Reply With Quote
Old 01-23-2018, 07:12 PM   #4
Ggmac
They all use the same basic design . The Mustang 2 parts must fit all so the strut lee lowers are all I use now .
Old 01-23-2018, 08:23 PM   #5
tomkowal
i have done a dozen mustang ii front ends and have always used tubular struts--you will get a much better ride..................
tomkowal is offline   Reply With Quote
Old 01-24-2018, 07:50 AM   #6
woodiewagon46
If I'm not mistaken I read somewhere that Gary Heidts purchased Chassis Engineering. I would give Heidts a call.
woodiewagon46 is offline   Reply With Quote
Old 01-24-2018, 08:17 AM   #7
waterboychuck
waterboychuck's Avatar
I used Speedway's lower control arms but still have the struts sitting on a shelf in my shop. PM me if you're interested.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 01-24-2018, 10:06 AM   #8
TJ
TJ's Avatar
The lower rear brackets for the CE Mustang II are an essential part for the bolt in crossmember. They stabilize the lower part of the main crossmember to the frame rails. Since you have a pattern on the '36, you can fabricate the brackets you need. You don't need to drill the brackets for the strut rods. Then buy the pieces that allow you convert the crossmember to the full A arms on the bottom. That will eliminate the need for strut rods.
Old 01-24-2018, 11:59 AM   #9
38bill
38bill's Avatar
I went strut-less on mine. You can see the bushing and gusset welded to the cross-member. I going to go out on a limb and assume that if struts were used... the strut rod (with rubber bushings) would go through the round hole that can be seen in the lower rear brackets.
38bill is offline   Reply With Quote
Old 01-26-2018, 01:18 AM   #10
Spiffy
Spiffy's Avatar
1 9/16"
Spiffy is offline   Reply With Quote
Old 01-27-2018, 07:50 AM   #11
cbillelder
Thanks Spiffy, that's the number I was looking for.
