09-12-2017, 11:57 AM | #1 |
1932 Beep Horn
I have a '32 Ford "Beep" horn that I want to restore and convert to 12 Volts. Dave Cole in one of his V8 Times articles mentions using newer 6 volt horn parts to do this. Looking for advice on what 12 volt horn or parts to look for. Thanks, Ted
09-12-2017, 01:29 PM | #2 |
Re: 1932 Beep Horn
I'm sure there are several options about this. I suggest you restore the horn as 6 volts. Just as it came from the factory. The voltage is hot to the horn. The circuit is completed by pushing the horn button to ground. Install a resistor inline before the horn. Thus reducing the voltage from 12 to something less....hopefully 6 volts. Not a uncommon thing to do. All of the Ford Falcons and early Mustangs used 6 volt instruments thru a voltage drop/resistor. I think Vintique sells a Resistor/voltage drop. Have fun.
09-12-2017, 05:26 PM | #3 |
Re: 1932 Beep Horn
Thread Tools | |
Display Modes | |
