12-24-2013, 11:27 AM | #1 |
260 motor parts
Friend has parts for 260 motor, heads, cam, crank, manifolds and pan. Are they worth anything or should I advise him to take to junk yard. Thanks
12-24-2013, 02:29 PM | #2 |
Re: 260 motor parts
Since they are becoming rare I would not trash them,the first Mustangs had a 260 and someone doing a restoration will pay good cash for numbers matching parts and the 5 bolt bell housing blocks are getting very scarce,Example: http://www.ebay.com/itm/260-Ford-Eng...56c643&vxp=mtr .I suggest doing a search on ebay and www.zoomthelist.com to see what they are bringing there is some good tech info here:http://www.mre-books.com/interchange/index.html Click on the letters in blue so you can break down the codes.
12-24-2013, 08:23 PM | #3 |
Re: 260 motor parts
also the crank and many other parts fit a 289.
12-24-2013, 11:05 PM | #4 |
Re: 260 motor parts
There are a lot of guys working with early Fairlanes as well as the guys with 64 1/2 Mustangs, both of which used a 260.
12-25-2013, 09:43 AM | #5 |
Re: 260 motor parts
Plus Falcons and Comets,,,,
12-25-2013, 10:46 AM | #6 |
Re: 260 motor parts
