09-09-2011, 05:02 PM | #1 |
Engine colours
Hi,
all the engine were painted green ? My engines and transmissions (July '28) were painted green ? Mine is painted as the FORD tractor's engine (light blue), same as used on GPW JEEPS during the WWII. Thanks in advance for your information. Uploaded with ImageShack.us Cheers, Charlie Saguier
Charlie Saguier Ford Model A Roaster Pickup 1928 Jeep Willys CJ-2A 1947 Jeep Willys MB Slat Grill 1942 |
09-09-2011, 05:42 PM | #2 |
Re: Engine colours
Engine block, head, side cover, crank pulley, intake manifold, clutch housing, bell housing, transmission, water input casting and goose neck, water pump are engine green.
Front and rear motor mount, oil drain tube, fan, generator, starter, pan, universal clam shell and behind are black. I like high temperature cast iron color paint on the exhaust manifold even though they came with no finish. Richard Anaheim CA |
09-09-2011, 05:55 PM | #3 |
Re: Engine colours
Canadian Manufactured cars used Ford Engine Green and my have also used Ford Engine Gray. It is referenced in the Canadian section of the Judging Standards.
I have never seen the Ford Engine Gray, although I would like to get a sample. Does your Engine have a Canadian Serial Number ? |
09-09-2011, 05:57 PM | #4 |
Re: Engine colours
I wonder if Ford Engine Gray was the same as Fordson tractor gray ?
09-09-2011, 08:04 PM | #5 |
Re: Engine colours
09-09-2011, 08:38 PM | #6 |
Re: Engine colours
Pete's Ponies Mustang RUSToration & Performance |
09-09-2011, 08:39 PM | #7 |
Re: Engine colours
might you have a tractor motor?
i think finding not original engine colors adds a great mystery. my station wagon cowl came to me ford green (sort of ), i've worked my way thru to the tern coat. the motor was manila brown. i wonder why the mix up. and my nineteen forty seven willys cj2a has a mid thirties block with a willys jeep head on it. all painted factory rebuild red. was the color decision made for factory and shipping reasons ? indications of compressions, horsepower, implications ? |
09-09-2011, 10:08 PM | #8 |
Re: Engine colours
My June '28 Canadian-built Phaeton engine had traces of blue-gray paint behind the engine mounts. It had been repainted the dark Ford green when I bought it.
09-10-2011, 07:13 AM | #9 | |
Re: Engine colours
09-10-2011, 12:27 PM | #10 |
Re: Engine colours
doubter,
enough research has been put forth to determine that i do in fact own a post war vehicle with a pre second war motor. no need to argue the fact, the desert is littered with compilations . i'v acquired a mysterious item and have narrowed it down by way of matching numbers. i'm in no way a purest, however enjoying the functioning originality of the design and intentions of application is all i'm after . as for charlie jeep's motor color, i find it interesting enough to ask, if the motor # matches the frame # ? then you know what you've got a gray A motor. otherwise look into it as some advancements had occurred rapidly. what ever your intentions are and direction you go with it is up to you. if it is originally from another vehicle, tractor, or less mobile functioning equipment and put to use in your model A , good for you and keep it running . thanks for sharing . |
09-10-2011, 01:28 PM | #11 | |
Re: Engine colours
My car came from a ranch near Bieber, in very rural northern California. It was parked in the barn in '47 and I got it in '62. It had the original block with 0.040" pistons. Joe
1929 Tudor since 1962 Feather River A's |
09-11-2011, 09:21 AM | #12 |
Engine colours
Hi Guys,
thanks for your replies and interest in this topic. My Model A 1928 (and all the Model A in Argentina are RHD). Do you think that all the cars were produced in Canada ? or in the USA? Here is a photo of my engine Serial Number Uploaded with ImageShack.us It say FORD USA. Somebody can post a photo of a Canadian Serial Number ? Note : impossible to see the frame number Cheers, Charlie Jeep
Charlie Saguier Ford Model A Roaster Pickup 1928 Jeep Willys CJ-2A 1947 Jeep Willys MB Slat Grill 1942 Last edited by Charlie jeep; 09-11-2011 at 09:27 AM. |
09-11-2011, 11:09 AM | #13 |
Re: Engine colours
The Hollander interchange book shows that Willys used the same 4cyl head
from 1933 to 1948. Bob |
09-11-2011, 04:33 PM | #14 | |
Re: Engine colours
This does not have anything to do with the color of a Model A engine,whatever the origin. |
09-11-2011, 04:52 PM | #15 |
Re: Engine colours
whatg color is the flywheel inspection plate?
09-11-2011, 06:44 PM | #16 |
Re: Engine colours
Export models were built in Canada and shipping from CA.
Do you have Roberts screws in your interior wood framing, if so Canada. (square indent for screw head) |
09-11-2011, 10:13 PM | #17 |
Re: Engine colours
There is a 1931 Canadian Victoria that just got listed on ebay... looks to be relatively unmolested. The engine looks gray to me.
09-12-2011, 02:53 PM | #18 |
Re: Engine colours
Hi fordgarage.
many thanks for your answer and congrats for your site !! Cheers, Charlie
09-12-2011, 05:23 PM | #19 |
Re: Engine colours - Canadian Engine Number Photo
Here is a photo of a Canadian Engine Number. Note this is a CAE number, many publications, including the Judging Standards (not certain about 2011), list CAW twice instead of CAE. Which was produced 2-1930 until 3-1930. I have my Canadian Phaeton with me and I will try to get a photo of the number on it shortly.
Darryl Fairbanks |
09-12-2011, 05:40 PM | #20 |
Re: Engine colours - Canadian Engine Number Photo 2
This is a photo of my Canadian Engine Number
Thread Tools | |
Display Modes | |
