02-10-2021, 06:36 PM | #1 |
rear differential ratio
just bought a 34 cabriolet and i would like to know what the rear end gear ratio is. is there a way to tell without opening the the rear end and counting the teeth
02-10-2021, 06:45 PM | #2 |
Re: rear differential ratio
The ring and pinon numbers are supposedly stamped on the bottom of the center section of the rear end. Notice I said supposedly because I can't find any numbers on the rear end in my '39 p/u although I've tried on several different occasions.
Making the simple complicated for over 30 years. |
02-10-2021, 07:22 PM | #3 | |
3.54 = 11/39 3.78 = 9/34 4.11 = 9/37 The number of teeth on your ring gear should match ONE of the last numbers in each of the above. DD |
02-10-2021, 07:33 PM | #4 |
Does it have a starting handle? (crank handle)?
If so you can jack up one rear wheel, put it in top (high) gear, and turn the handle until the raised wheel has turned exactly 2 revs. The number of turns of the crank handle equals the axle ratio. The possibilities are listed above so it should be easy to work out which one you have. Most likely is 4.11 This video may help. https://youtu.be/bkvp3Fq21ZM Mart. Last edited by Mart; 02-10-2021 at 07:49 PM. |
02-11-2021, 12:12 AM | #5 | |
With the spark plugs out!
Alan |
02-11-2021, 07:10 AM | #6 |
02-11-2021, 08:03 PM | #7 | |
02-11-2021, 09:33 PM | #8 |
That's true with both wheels up (and they turn together). With one wheel fixed the spider gears come into play.
02-11-2021, 09:38 PM | #9 |
What about checking the number on the turtle? Will that tell you the ratio?
02-11-2021, 11:40 PM | #10 | |
02-12-2021, 06:25 AM | #11 |
Thanks for the chart. That explains quite a bit. I have seen mostly 3.78 rears and #19.
I keep hoping I will find 3.54 rear some day. |
02-12-2021, 11:21 AM | #12 |
