02-06-2021, 10:24 AM | #1 |
Brake Question...Again 1957 Thunderbird
Seems I have an out of round brake drum. Am I mistaken in thinking the front drums and hubs are one piece? I see offerings from vendors for front drums less the hubs but I believe my hubs/drums are one piece. Maybe the hubs are riveted to the drums? Referenced my shop manual but have not found anything yet. Help!
02-06-2021, 01:25 PM | #2 |
Re: Brake Question...Again 1957 Thunderbird
OEM were drum/hub assy.
It seems current service replacement is drum only and/or hub only. The drum is pressed onto the hub. EDIT - Added text is in heavy text.
***** - DISCLAIMER -
The above posted information is in my opinion only (IMO) and may contain copy and paste material(s). In addition, any above tech information is supplied in good faith. No responsibility implied or otherwise can be accepted for the way others use or interpret provided data. Your experience(s), opinion(s) and mileage may vary. DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 02-07-2021 at 03:23 AM. Reason: CLARIFICATION |
02-06-2021, 01:31 PM | #3 |
You are not getting NEW Hubs -- and you do not need Hubs, period....(99 % of the time)...
The hubs and drums are pressed apart, and then the Hub is then pressed to the NEW brake drums.... Certainly best to have an old school machine shop do it correctly.... If you want NEW Brake Drums and ++ N.O.S. ++ Asbestos ++ Brake Shoes ++ Always best to simply call me -- Craig -- 516 - 485 - 1935.... New York.... |
02-06-2021, 05:07 PM | #4 |
Most of the old Fords had rear hub & drum assemblies back in the Lockheed brake era. They were held together by the lug studs which were swaged to hold them tightly. I'm not well versed on the baby birds but it would be nice to know if they are similar in that respect. It takes a tool to cut the swage and a tool to swage the new studs on the old cars but later ones may just be a tight press fit. It was common on Fords of the late 40s & early 50s to have three bolts holding the hub & drum together on front wheel brake drum applications. The drums were centered by the inner diameter fit to the hub snout.
02-07-2021, 03:16 AM | #5 | |
The above posted information is in my opinion only (IMO) and may contain copy and paste material(s). In addition, any above tech information is supplied in good faith. No responsibility implied or otherwise can be accepted for the way others use or interpret provided data. Your experience(s), opinion(s) and mileage may vary. DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
02-07-2021, 12:17 PM | #6 |
02-10-2021, 08:39 AM | #7 |
02-10-2021, 08:28 PM | #8 |
Local shop was successful in machining the drum with the hub in place. The i.d. measured right at 11" so it had never been turned before. I swept the drum braking area with a dial indicator before I took it to the machine shop and found it to have about .040" runout. It was definitely warped from overheating. It is all installed now and I'll test out the brakes this coming weekend.
03-05-2021, 03:44 AM | #9 | |
Thread Tools | |
Display Modes | |
