Old 11-22-2011, 10:54 AM   #1
Charlie jeep
Default Help - find a new part
Hi,
I need some help with this part.
I would like to replace this part for a new one, but I didn't find it in any of my Part List Catalogues (Mac's- Snyders- Bratton's)
Uploaded with ImageShack.us
Any idea or help would be appreciate.
Cheers and tks,
Charlie Saguier
Charlie Saguier
Ford Model A Roaster Pickup 1928
Jeep Willys CJ-2A 1947
Jeep Willys MB Slat Grill 1942
Charlie jeep is offline   Reply With Quote
Old 11-22-2011, 11:21 AM   #2
JBR
JBR's Avatar
Default Re: Help - find a new part
I don't think they are being reproduced. You will probably have to find a good original.
JBR is offline   Reply With Quote
Old 11-22-2011, 12:40 PM   #3
Clem Clement
Clem Clement's Avatar
can you use a Dremel and deepen the grooves? Are the little springs on the rods in good shape?
Clem
Old 11-22-2011, 01:12 PM   #4
Kevin in NJ
Chisel to make the grooves better. This works better because it pushes the surrounding metal up.
Make sure your rods are back to the original diameter. Works way better then I thought it would.
I was told to do this a long time ago by those who know A's.
Old 11-22-2011, 01:55 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I would fix it the way Kevin said, then when the steering is all done put a dab of grease on the wear path, so it lasts longer.
Old 11-22-2011, 06:22 PM   #6
RHD
RHD's Avatar
I have used a 3 cornered file for deepening the grooves. Make sure the corresponding part on the spark and throttle rod is welded and filed round, or you will lose the ratchet effect.
R.H.D.
Author of Model 'A' Ford technical manuals.
Supplier of good original RHD parts.
RHD is offline   Reply With Quote
Old 11-22-2011, 11:00 PM   #7
hardtimes
hardtimes's Avatar
I second this 3 cornered file method, as it worked well for me!
Old 11-23-2011, 05:44 AM   #8
Tim B.
File is called a Knife file. Smaller ones have a finer taper so you can better control the cut. Works well on threads as well if you are in a tight spot or don't have a thread file or a die handy.
Tim B. is offline   Reply With Quote
