01-11-2012, 12:11 PM | #1 |
Crab Dist Adapter
I have a 59 AB engine with a Helmet Dist. Can someone tell me where to purchase an adapter to run a 42 Crab dist???. I have two good crab Dists. and would like to run on of them.Thanks
01-11-2012, 12:43 PM | #2 |
Re: Crab Dist Adapter
I think this is what you need:
http://www.speedwaymotors.com/Flathe...pter,6003.html Plus, 2-3 bolt plate that you can probably get from Bubbas, or ThePitstopGary has one as well - about $55. |
01-11-2012, 12:44 PM | #3 |
Dick Spadaro.com
800-222-3248 |
01-11-2012, 12:48 PM | #4 |
Oh,John i didn't know Dick carried them,thanks. ken ct.
01-11-2012, 02:41 PM | #5 |
Thank you very much for the help. You guys are the best;
David |
01-11-2012, 03:35 PM | #6 |
01-11-2012, 08:05 PM | #7 |
In my experience, helmet distributors are not usually on 59AB engines, they have the crab distributor housing with either the flat, Mallory style, cap or they have the large plastic cap with the rubber boot on each side. If you have that, then you can just add the '42 clips and a '42 cap. If a helmet distributor is on a 59AB then it may already have an adaptor or it may have the wrong cover on it. I guess that's the thing to check is whether your timing cover is a 2 bolt or 3 bolt?
01-11-2012, 09:27 PM | #8 | |
01-11-2012, 10:29 PM | #9 |
Thanks all::
This engine has a three bolt timing cover and a helmet Dist. I think with the help here I now have this figured out. Thanks again David |
01-12-2012, 01:49 AM | #10 |
Personaly i think your going through a lot of trouble and work to gain almost nothing. Helmets run just as well as the crab when done up right. OMO ken ct.
01-12-2012, 10:01 AM | #11 |
Doesn't the helmet dist have to have the longer cam snout with the original three bolt cover?
01-12-2012, 02:38 PM | #12 |
If you have a helmet dizzy currently running and you take it off, a crab style dizzy will bolt up with just the adaptor, no spacer required.
I have this setup on two of my engines. Mart. |
01-12-2012, 02:45 PM | #13 |
It's a distributor!
01-12-2012, 02:48 PM | #14 |
I would have to agree with some of the others. although we do tons of the crabs the helmet is just as good in all respects...
Both are very good examples of early Frod ignition and are just about perfect when matched up with good parts, coil and a proper set up... |
01-13-2012, 09:21 AM | #15 |
I'm still a bit confused The adapter you speak of is the three bolt to two bolt, like speedway sells? Then no "button" is required when combining the crab with the longer cam?
01-13-2012, 10:14 AM | #16 |
Both styles of the pancake dist have long snouts on them obviously to reach in further to reach the shorter cam in the 42 and up engines.Unless the mount surface of the 2 bolt cover is further out more than the helmet covers. Then why is 1/2" spacer made in the first place. ??? ken ct. I am NOT talking about the button which is a diff situation again.
