01-20-2021, 02:00 PM | #1 |
1946 Mercury exhaust system source?
Who has the best exhaust system components for a '46 Mercury? The only place I've found that carries any of the larger pieces is Mac's.
Thanks in advance. |
01-20-2021, 02:21 PM | #2 |
Re: 1946 Mercury exhaust system source?
Check with Waldron's, waldronexhaust.com. They do a lot of vintage car exhaust systems.
01-20-2021, 03:46 PM | #3 | |
Red's Headers? https://www.reds-headers.net/
01-20-2021, 04:44 PM | #4 |
I think Ford pipes will work but need to be lengthend
at the mufflers. G.M.
www.fordcollector.com |
01-21-2021, 12:54 AM | #5 |
George, along the line of what you posted, I'm curious. My recollection is that the engine in a 46 Merc, sits in the same place as in a 46 Ford, in relation to the firewall and all points rearward. Is that so? And, if so, wouldn't the exhaust system for the Merc be the same as for a Ford? I don't really know, and I'm just speculating...
01-21-2021, 12:37 PM | #6 |
01-21-2021, 01:05 PM | #7 | |
shaft and rear from a 1948 Mercury and it was 8 or so inches longer. G.M.
01-21-2021, 04:40 PM | #8 |
I think you'll find that the extra length is due to shifting the front axle forward, the drive train is the same dimensions on both ford and Mercury.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
01-21-2021, 07:00 PM | #9 |
The added length of the Mercury is forward of the cowel.
The motor and drive train is is in the same location as a Ford. The difference happens with the steering gear, about 4 inches more forward than a Ford, which creates a different interference for the dual side pipe if installing dual exaust. Single, stock exhaust system with cross over pipe is the same for 42-48 Ford or Merc. I have a Waldron dual side exhaust pipe for a Mercury if anyone is interested. |
