Old 10-02-2020, 03:18 PM   #1
Werner
Werner's Avatar
Default wrong / worn axle shims
Guten Abend!
About 3500 ml / <2 years ago I revised all the brakes. Since the rear brake drums were too loose on the axle cone, I used the thin spicer / cone / axle shim.
Today I installed new brake shoes because the old ones were still thick, but led to extreme fading because overharding, I think.
I noticed that the mounted spicers were crushed and crumbly.
Did I do something wrong with the assembly back then?
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 10-02-2020, 07:05 PM   #2
sofield
Default Re: wrong / worn axle shims
Originally Posted by Werner View Post
Guten Abend!
Place the shim in the hub first that way the shim won't slide off the taper.
sofield is offline   Reply With Quote
Old 10-03-2020, 11:45 AM   #3
Jim Brierley
I doubt that you did anything wrong, stuff just happens. Many axles and hubs have been damaged over the years. I try to smooth the axle with a file, can't do much with the hub.
Jim Brierley is online now   Reply With Quote
Old 10-03-2020, 02:46 PM   #4
Pete
Pete's Avatar
The best use of axle shims is to quickly move a used car off the lot before the 30 foot warranty expires.
