10-01-2020, 07:52 PM | #1 |
oil on floor under flywheel
flywheel cover is off
oil is all around on both sides (blown around) how do i know if its rear main |
10-01-2020, 08:24 PM | #2 |
Re: oil on floor under flywheel
If the front of the flywheel is wet, oil is leaking from the main seal or the aluminum bracket that holds it. If the rear of the flywheel is wet, the trans is leaking, the torque converter, or the throw out bearing. In any case, it will be a lot of work to repair, If you have a small puddle, it may be easier to live with it.
10-02-2020, 07:35 AM | #3 |
drip from time to time
fly wheel and clutch are dry back of oil pan and oil pump , trans ,starter won't stay dry so there is a small leak and flywheel is blowing it around |
10-02-2020, 02:43 PM | #4 |
What I've always done to trace a leak is this:
Clean off garage floor with sawdust and sweep away clean and dry. Get under car with a shallow tub filled partially with gasoline and a soft cloth and clean away all the oil seepage, then get a dry cloth and dry real good. Run engine a while and pull the car back onto garage floor. Wait till you see one drip spot and crawl back under car and trace the leak to it's source. May need to take flashlight and use your bare finger to detect wet oil. |
10-02-2020, 03:21 PM | #5 |
