Old 10-30-2020, 07:48 PM   #1
Blastfromthepast
Default 1936 LB engine block internal scale clean
Has anyone ever used an internal block cleaner.
I need to remove rust scale form the heads and block
Without opening up the engine. Any suggestions? Blast.
Blastfromthepast is offline   Reply With Quote
Old 10-30-2020, 10:25 PM   #2
Aarongriffey
Default Re: 1936 LB engine block internal scale clean
CLR.
Calcium,lime, rust.
Get it at a hardware or building supply store.
Mix it with water. It’s for flushing water pipes.
Leave it in Half hour.
There’s also a product by RustOleum called rust dissolver.
I got mine at Auto Zone. About $20 a gallon.
Aarongriffey is offline   Reply With Quote
