12-06-2019, 09:01 AM | #1 |
U Joint Quality
Does anybody make a high quality US-made U joint ? Are 1928 -1948 U joints interchangeable ? Not impressed with a foreign-made unit I have. Spline bores appear to be off center and there is perceptible axial play.
12-06-2019, 09:08 AM | #2 |
Re: U Joint Quality
Call up Berts and see if he has a good used one. That's the route I went after he told me the rebuild kits are poor quality. The one he sent me looked and felt almost brand new.
Alternatively, Bob Drake makes a modern replacement that uses needle bearings. Have read mixed reviews on it. |
12-06-2019, 10:54 AM | #3 |
Re: U Joint Quality
The 28-48 U joints are interchangeable I believe. that is the ones where you can replace the wear parts.
12-06-2019, 12:56 PM | #4 |
Re: U Joint Quality
I checked five, some NOS, and all have about 1/16" axial play.
12-06-2019, 02:49 PM | #5 |
Re: U Joint Quality
I think the one with the needles is a copy of the Lincoln U-joint.
12-06-2019, 03:50 PM | #6 |
Re: U Joint Quality
Looking hard at the Bob Drake option. Since the needle bearings are sealed the unit would probably not benefit from filling the U joint enclosure with mega grease. Quality looks good but do not know if US-manufactured. Anybody have any experience or info on this unit ? |
12-06-2019, 03:51 PM | #7 | |
Re: U Joint Quality
The US has about 5% of the world's population. That means that to 95% of people, US made is "foreign made".
12-06-2019, 03:51 PM | #8 |
Re: U Joint Quality
Call them...................
Paul in CT |
12-06-2019, 03:53 PM | #9 | |
Re: U Joint Quality
12-06-2019, 05:14 PM | #10 |
Re: U Joint Quality
There was some discussion of the needle-bearing U-joints on the Early V8 Forum a while back and the consensus seemed to be that this type of bearing was unnecessary in an application where there was no full rotation around an axis. These were used in some Lincolns of that era and many assumed that made them better than the Ford supplied bushing U-joints, but actual use showed no advantage.
12-07-2019, 08:54 AM | #11 | |
Re: U Joint Quality
Good point! |
12-07-2019, 09:21 AM | #12 | |
Re: U Joint Quality
There has NOT been much (if any) good to say about Bob's repro Lincoln joint....do a search re: "Bob Drake U-joints". Contact Fred Wilmer at Southside Obsolete for REAL Ford NOS joints. Send Fred a PM...he goes by "barnfind08" here on the 'Barn. DD |
12-07-2019, 09:38 AM | #13 |
Re: U Joint Quality
Did some research and agree. Needle bearings appear to be not the way to go on torque tube drive lines. Since the shafts are restrained they must be in perfect alignment to avoid side loads on the joint. The bushing type joints readily accommodate minor lateral misalignment. Many antique Lincoln owners report they retrofit their rides with bushed joints because they last much longer. Appreciate the input and recommendation. NOS is clearly the best route to go.
12-07-2019, 10:17 PM | #14 | |
Re: U Joint Quality
Rumors and speculation are dangerous. |
12-07-2019, 10:58 PM | #15 |
Re: U Joint Quality
Recently there U-joints on the market supplied by your favorite supplier that were too wide to properly fit inside the U-joint housing. Most of the better suppliers pulled them from their inventory when they were advised of the problem. Other suppliers didn't. So beware!
Out here in California serviceable original U-joints are seen all the time at swap meets for next to nothing. Tom Endy |
12-08-2019, 01:00 AM | #16 | |
Re: U Joint Quality
As I've said before, you guys don't know how good you've got it.
