Old 11-06-2019, 01:57 PM   #1
Mulletwagon
Mulletwagon's Avatar
Default Spring Prep
Just got a new rear spring fir the 31. It is in raw steel. Any special prep, other than painting, required before installation ?
Mulletwagon is offline   Reply With Quote
Old 11-06-2019, 02:02 PM   #2
Curtis in MA
Default Re: Spring Prep
If you go to A-Springs.com, click on any spring you will see a link to a prep guide.
Clean and de-grease first.
Curtis in MA is offline   Reply With Quote
Old 11-06-2019, 08:13 PM   #3
mhsprecher
mhsprecher's Avatar
I read "Spring Prep" and thought, huh, winter will soon be upon us. Joke's on me. ;-)
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 11-08-2019, 08:01 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
Solvent clean, spray with gloss black paint and install spring covers wet with 140 gear oil.
Bob Bidonde
Old 11-08-2019, 08:25 AM   #5
mike657894
mike657894's Avatar
I use grease between the leaf. Ive been thinking about adding gaiters to keep the grease clean.
mike657894 is offline   Reply With Quote
Old 11-08-2019, 03:32 PM   #6
AL in NY
AL in NY's Avatar
I put new springs on my 30 CCPU last fall and there are two important things that should be done to achieve the smoothest ride possible. First, the springs should be taken apart and the sharp edges at the ends of each leaf should be rounded off so they don't dig into the surface of the leaf below. Second, the surfaces of the leafs that come into contact with each other (top of lower leaf and bottom of upper leaf) should be painted with a graphite based paint like "Slip Plate" or "EZ-Slide" to ensure good spring movement. Then re-assemble the spring, wipe off any excess graphite paint with kerocene, then paint with a good spray paint. I know this sounds like a lot of work, but you'll really enjoy the smooth ride.
AL in NY
AL in NY is offline   Reply With Quote
Old 11-08-2019, 04:08 PM   #7
rocket1
I just want to add use extreme caution with that rear spring,you can't always relay on that center bolt holding it together.I would chain it or large c clamp it before you are ready to install it.
rocket1 is offline   Reply With Quote
Old 11-08-2019, 04:48 PM   #8
100IH
The more lube on the spring leaves, the more you're relying on good working shocks for the smooth ride. Some friction is part of the equation.
100IH is offline   Reply With Quote
