02-13-2019, 11:16 PM | #1 |
RTS F150 OD TRANSMISSION TORQUE Tube IN A 34 COUPE
Has anybody installed a rts f150 od transmission in a 34 coupe with keeping the torque tube? I need info on this combination. Does anybody make a kit? This combination keeps the shifter location near stock.
02-13-2019, 11:38 PM | #2 |
Re: RTS F150 OD TRANSMISSION TORQUE Tube IN A 34 COUPE
This is a great transmission 3 speed with od. Yes someone does convert these to torque application. However converting to a spicer/Dana 35./44 and you would remove all the problems with the original rear axle. Probably for the same price as the conversion/.
02-13-2019, 11:58 PM | #3 |
I would like to keep the original look. I might send the rear end to Hotrod works so they can install there axle swap kit.
02-14-2019, 08:27 AM | #4 |
02-14-2019, 09:03 AM | #5 |
Hotrod works is a great outfit. They can also convert the axle to a modern break kit both drum or disk. You can also change to 5 on 4 1/2 bolt pattern for a better selection of Wheels. I did this with the instillation of a Dana 44a rear, this comes with posi and disks and is a very inexpensive up grade compared to the Hotrod unit. I don't have the financial resources to do it any other way. Aesthetics can be expensive.
02-14-2019, 09:51 AM | #6 |
02-14-2019, 01:47 PM | #7 |
Anyone know where I can buy one of these RTS F150 transmission’s?
02-14-2019, 04:39 PM | #8 |
There are web sites that can access the salvage yard network. I see them on flea-pay now and then but a lot are for the 6-cylinder applications that have the taller overdrive gears. The few guys that set up conversions for these tend to hoard parts. I've looked for the better overdrive ratio gear for these but they are not easy to find.
02-14-2019, 07:46 PM | #9 |
Took me years to find one and I had to settle for the 6 cylinder one. I still need to find the Speedo drive housing, not sure where to look.
02-14-2019, 08:03 PM | #10 |
I have had the 6 cylinder version in my car for over 20 years now. I like it.
02-14-2019, 09:41 PM | #11 |
I did my 36 with a Flathead, T170 RTS 4 speed and a a Columbia with 3.78 R&P
PM me for all the details via a phone call |
02-15-2019, 11:57 AM | #12 |
I use the steel bell housing for the engine adapter. Bore the register to fit the trans and weld ears on the bell housing. Use stock clutch assy. You can buy a kit to install a modern real axle to the car. Do not install a heavy axle as this can give poor ride quality, a Spicer 35 is light and can handle more than a flathead can put out. This make a nice street riding acr. I was talking to a tire dealer recently, and he said the 15" tire is on the way out and the 16" will continue for quite awhile. Scrap yards are full of Alum wheels and usually go for 15 25 apiece, so a nice set of rims can be had. I use a disk adapter for the front with 5 on 41/2 same as the rear, Modern trans rear axle and decent breaks and wheels . This kind of modification will make the car usable for the next 20 years or more at very little initial investment.
02-15-2019, 12:05 PM | #13 |
Thanks, Ron.
02-15-2019, 12:57 PM | #14 |
Boy, I don't know. The little lady's Kia Soul has 15's and you know how many of them are out there. Size selection will probably be a problem though. I do know 13" and 14" tires are extremely hard to find.
