10-28-2016, 03:55 PM | #1 |
Generator belt
I am putting a 59ab flathead in a 34 ford coupe. Does anyone have a part number for a generator belt that will work for my set up? I am running a thickstun high rise manifold and the 59ab generator with a earlier style pulley so I can still run the fan off the pulley.
10-29-2016, 05:59 AM | #2 |
Re: Generator belt
Try a Gates "B 54" kx
10-29-2016, 06:28 AM | #3 |
Re: Generator belt
I use a B53 belt on my roadster. The B denotes the width of the belt, the 53 is the nominal length in inches. The designation is generic, by which I mean any manufacturer's B53 or as Kerk is using, a B54 belt should work. you don't necessarily need a Gates belt. Any industrial supply (bearings, belts, pulleys etc) should be able to supply a B53 or B54 belt. You don't necessarily need an automotive supply place or a specific part number.
Mart. |
10-29-2016, 12:31 PM | #4 |
Re: Generator belt
