Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 10-25-2011, 07:57 PM   #1
ct50f1
ct50f1's Avatar
Default F-1 upper rear shock mount stud
City: Glastonbury
State: CT
Looking for the shoulder bolt, 6" long, that goes through the rear frame on a '50 F-1 and attaches the upper end of the shock absorber to the frame. Would take two if you have them. Must be in good shape. One of the ones I have is pictured below.
ct50f1 is offline   Reply With Quote
Old 10-25-2011, 09:42 PM   #2
Redhorse1947
Redhorse1947's Avatar
Default Re: F-1 upper rear shock mount stud
I should have two of these. Will check tomorrow and let you know.
Also, see your private messages.
Redhorse1947 is offline   Reply With Quote
