05-19-2012, 11:48 AM | #1 |
8BA motor with sticky valve
Valve is sticking on my '49. It runs good on the road, but as soon as I stop at a stop sign or light at slow idle it stumbles and will stop. I have to
pull the choke out to keep it running. I tried some Deep Creep, spraying it down the carb with the engine running about 1/2 throttle, helped for a short time, but its back. Any ideas?, Maybe MMO in the oil?? I run MMO in the gasoline now....... |
05-19-2012, 12:22 PM | #2 |
Re: 8BA motor with sticky valve
What makes you think it is a stuck valve? Souns more like a carb problem
05-19-2012, 01:03 PM | #3 |
Carb adjustment, or fuel pump flex line or fuel pump glass bowl gasket. |
