08-04-2020, 08:46 PM | #1 |
Lost part, lock ring for speedo
Took the cable off seven years ago when starting my project and noticed today that I can't find the screw ring that holds the speedo cable to the drive shaft. Any idea on who might have a replacement part? So much for thinking of everything! lol.
08-04-2020, 08:55 PM | #2 |
Re: Lost part, lock ring for speedo
Holy cow, I didn't know you could get that piece off the cable assembly without destroying it. I will have to look at mine again.
08-05-2020, 12:57 AM | #3 |
Are you sure it hasn't slid back ? To put the replacement nut on that is gone ,one end that is crimped will have to be removed .Suggest you replace the cable & casing assy. Not expensive.
08-05-2020, 09:38 AM | #4 |
It shouldn't come off unless the cable end has been damaged. I'm betting that it has slid forward on the cable.
08-05-2020, 11:05 AM | #5 |
