Old 08-03-2020, 04:31 PM   #1
Topher5150
Default Window cranker repair 47 coupe
I picked up a pair of doors for my project. The shaft where the crank handle is rounded off pretty bad. If I can't get the reg out of my junk door w/out killing it is there a way to repair it?
Topher5150 is offline   Reply With Quote
Old 08-03-2020, 05:32 PM   #2
RalphM
RalphM's Avatar
Default Re: Window cranker repair 47 coupe
Better to replace it. NORS ones are still available. Check with Regulator Roy 609-828-8537.
RalphM is offline   Reply With Quote
Old 08-03-2020, 05:32 PM   #3
meric42
meric42's Avatar
Do you mean window riser or vent window crank?
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 08-03-2020, 06:00 PM   #4
Topher5150
The riser for the main window. I have one in a junk door but I can only get half a crank out of it. Not sure if it's the gear or if everything else is rusted
Old 08-04-2020, 09:18 AM   #5
drolston
drolston's Avatar
Doesn't the window crank pin to the regulator shaft? If sloppy handle is the issue, you can line the handle with some strips of aluminum foil to give it a snug fit.
