07-30-2020, 11:59 AM | #1 |
37 -39 Vin Number and or titles needed 1/2 PU and Panel
Hello Guys
I have a 39 1/2 ton truck and a 37 Panel I need to find the VIN on the trucks. Both firewall plates are blank. Is there any other places on the frames or bodies I can find a number? I need to get these titles so I can sell them. Thanks |
07-30-2020, 12:39 PM | #2 |
Re: 37 -39 Vin Number and or titles needed 1/2 PU and Panel
Vin numbers are on top of frame near the steering box. You should be able to find them with a wire wheel or some sand paper.
07-30-2020, 12:59 PM | #3 |
This link may help. http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm
07-30-2020, 01:32 PM | #4 |
Thanks guys! I will get the wire wheel out see what I can find.
07-30-2020, 03:01 PM | #5 |
found them both Thanks again!
07-30-2020, 03:04 PM | #6 |
08-05-2020, 04:43 PM | #7 |
Numbers on Top of bell should tell you if transmission is correct also
