09-11-2016, 11:57 AM | #1 |
Staarting model A
I just got my model A so please do not hold it against me for a stupid question. The spark advance lever on the left side of the steering wheel . It says that it should be in the retard position. Does that mean the lever should be all the way up or all the way down where the hole is ? Thanks
09-11-2016, 12:03 PM | #2 |
Re: Staarting model A
up for retard.. I drove with a post-it notes on the dash to remind me which was hand throttle and which was advance /retard and which way to move the levers ....for 4 months when I first got an A!!
09-11-2016, 12:17 PM | #3 |
Hi John,
Thanks for such a humble and encouraging positive answer. Nothing like reading the very seldom honest Model A Forum responses which lets everyone know that we "all" experienced a Model A learning curve which appears to never end. |
09-11-2016, 12:19 PM | #4 | |
Charlie Stephens |
09-11-2016, 12:20 PM | #5 |
My grandfather told me that you start it "up"
easy way to remember |
09-11-2016, 12:34 PM | #6 |
Here is the playlist of videos that may help you. A lot more than you need, but they may answer a few questions. https://www.youtube.com/playlist?list...rIa0r_fFQcz4R0 |
09-11-2016, 12:35 PM | #7 |
So, to start
fuel on Left lever up [retard like everyone said] right lever down a bit key on push button pull out choke [and almost immediately release] Once started, left lever down half way to 9:00 [ up is 10:00, down is 8:00, almost] right lever back up enough to keep engine running once warm, at about very steady level 40 mph, move spark lever to position that seems to make engine the 'happiest'. Should be at about 9:00-9:30. Thats where to set spark lever for vast majority of driving. |
09-11-2016, 12:49 PM | #8 |
Here is my take on it. This follows the owner's manual, but is animated.
http://modelabasics.com/Starting%20&%20Driving.htm
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
09-11-2016, 12:54 PM | #9 | |
All the way down is 40* advance, and the Model A only needs about 28* at full speed. |
09-11-2016, 01:04 PM | #10 |
After following the steps in post 7 when it is cold outside ... if the engine promptly dies.
1. Open the GAV knob an additional 1/2 turn or so ... this gives a richer mixture so that the engine will not stall. 2. Repeat choke operation remembering that 1/2 second of choke is all that is needed. 3. Then turn GAV slowly clockwise as engine warms up ...1/4 to 1/2 turn off the seat after warmup is normal on most engines. For those with no experiences with a manual choke ... When using the choke: Remember that the choke only works when the engine is turning over. Do not laugh I went to help a guy whose car would not start ... He pulled the choke for a second and released it and then hit the starter. There is no accelerator pump on a Model A carb so pumping pedal has no effect. Last edited by Benson; 09-12-2016 at 08:57 AM. |
09-11-2016, 01:17 PM | #11 | |
Maybe Tom ... Years ago I saw instructions for installing a Winfield head that instructed owner to drill a hole and install a stop to limit the max advance to about 28 degrees when using the High compression head. |
09-11-2016, 01:30 PM | #12 |
Thanks very much guys
09-11-2016, 09:21 PM | #13 |
If you get in a habit of shutting down procedures like the levers up! key off gas off it will help with your start up procedures! You may want to know what could happen if you try to start with the spark lever down ---------- a broken starter Bendix
09-12-2016, 06:11 AM | #14 | |
Yep, agreed. fuel off spark up key off ammeter zero little mental checklists/habits are a good thing, especially as I [ I won't say we ] get older. |
