Old 08-08-2016, 09:50 PM   #1
1929
Default FS Ignition, who has one?
Does the distributor housing get very hot on your unit?
1929 is offline   Reply With Quote
Old 08-08-2016, 10:17 PM   #2
tbirdtbird
Default Re: FS Ignition, who has one?
it gets hot enough, as does a stock dizzy.....head temp will be prolly 180 or more, and exhaust is close by
'31 180A
tbirdtbird is offline   Reply With Quote
Old 08-08-2016, 10:23 PM   #3
DougVieyra
DougVieyra's Avatar
As a side note; The FS ignition requires a special coil (much more $$$). I love my FS ignition on my '31 Dlx Coupe, but confess, I do not do any touching of the distributor so can not attest to it's heat factor. As it sits on top of the engine, I suspect it gets hot enough to be called 'hot'. How much that heat effects the functional operation of the Electronic Ignition I do not know.
DougVieyra is offline   Reply With Quote
Old 08-08-2016, 10:40 PM   #4
tbirdtbird
"The FS ignition requires a special coil"
not that I am aware. Mine is not 'special' and it works just fine
I have to wonder what is going on that has triggered the OP to pose the question to begin with.......ie the back story
'31 180A
Old 08-08-2016, 11:36 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Fs sends a .6 ohm coil. The standard model a is 1.3 or 1.4 ohm. Bubba from the V8 site (spark gru) doesn't like the lower ohm coil, because it puts to much stress on the system.I've got 31,000 on the original fs .6 ohm coil, and it's been over heated overnite when new, and a month ago it was on for a week and ran the battery down. Have put another 1000 miles since then. Fingers crossed.
Old 08-09-2016, 12:32 AM   #6
CYB4
CYB4's Avatar
I have one without any problems. Never touched it for temperatures. Just get a coil for electronic ignitions, I got one from Bosch.
Best regards
Chris
Best regards
Chris
1930 Ford A Std. Tudor
CYB4 is offline   Reply With Quote
Old 08-09-2016, 06:14 AM   #7
1929
I have the special coil, just curious if its normal for the distributor to get as hot as the head.
Old 08-09-2016, 06:48 AM   #8
CT Jack
CT Jack's Avatar
1929, You need to explain what you think is a hot distributor problem. First of all solid state ignition systems do not generate heat. The module inside your distributor is nothing more than magnetic switch without any moving parts (no heat). You need to look elsewhere for your high heat problem. Have you oiled the distributor shaft bearing lately?
CT Jack is offline   Reply With Quote
Old 08-09-2016, 07:02 AM   #9
C26Pinelake
Great response! Wayne
C26Pinelake is offline   Reply With Quote
Old 08-09-2016, 07:47 AM   #10
jerry shook
I have the fs on my 31. what spark plug is needed, and what does the gap need to be.
jerry shook is offline   Reply With Quote
Old 08-09-2016, 09:58 AM   #11
V4F
V4F's Avatar
I'm using the new E plug with good success .
V4f
V4F is offline   Reply With Quote
Old 08-09-2016, 10:08 AM   #12
Jordan
Jordan's Avatar
We have FS Ignitions on all 3 cars and love all 3 of them. If they are installed correctly, you will never regret it!
Cowtown A's
Jordan is offline   Reply With Quote
Old 08-09-2016, 10:29 AM   #13
1929
I switched over to modern plugs, I was using the Champion W18 with a 35 cap before the switch to the modern plugs.
Old 08-09-2016, 10:43 AM   #14
Chuck Sea/Tac
I've always used the 3X . What ive noticed is they're only good for about 10,000 miles as the hot spark eats the electrode. Ive also had spark running down the outside of the plug. Could hear an erratic miss at idle, looked at it in the dark, and saw the "leak".
Old 08-09-2016, 12:45 PM   #15
barkleydave
barkleydave's Avatar
Running one for years.. No problems same setup but not fancy coil.
Have a relation has had the same FS unit in his slant for 18 years not one fault.
barkleydave is offline   Reply With Quote
Old 08-09-2016, 02:50 PM   #16
CYB4
CYB4's Avatar
Fs-Ignition recomments in their instructions a 1.3 to 1.5 Ohm coil at 6V Electronic Ignition Systems and 3.0 to 3.5 Ohm at 12 Volt systems. If the Ohms are not correct, you might get a hot distributor or you can destroy the ignition, as I know from my Harley-Davidson.
They also provide coils, which fit to the ignition.
Best regards
Chris
Old 08-09-2016, 04:53 PM   #17
harleynut
harleynut's Avatar
Call F S, there nice people they would be happy to answer any questions. I have them in two Models As with no problem.
harleynut is offline   Reply With Quote
Old 08-09-2016, 04:56 PM   #18
CarlG
CarlG's Avatar
I'm new to the FS game. Have about 800 miles, so far so good!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-09-2016, 06:04 PM   #19
Synchro909
Synchro909's Avatar
I've run a RS ignition system on a car for years. The first one I installed has done about 4 0,000 miles towing around the outback. Heavier loads on the engine mean higher cylinder pressures but it has performed well. I use TT10 plugs which I intend replacing before I go much further. They have done nearly 50,000 miles since I pit them in. The "special" coil that came with the kit failed recently and I replaced it with an ordinary one (Made in China) which is still going.
Mine has an automatic advance system that has worked well too. The only negative I can tell is that the small aluminium piece that replaces the cam was made wrong. The slot to locate the rotor button was cut in the wrong place so timing by the usual method is impossible. Almost everybody who fitted one over here at that time had the same problem.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 08-09-2016, 07:00 PM   #20
Herb Concord Ca
I've had mine in my roadster P/U for four years. The thing I noticed first is how easy the motor starts.
Like Doug I never checked the dist temp. I'm also using the same coil when it had points.
Herb Concord Ca is offline   Reply With Quote
