07-28-2016, 07:53 PM | #1 |
I didnt think it would work.
I didn't think my 12 volt timing gun would work on my 6 volt car, but it did, so the car has perfect timing and is running very well.
07-28-2016, 10:08 PM | #2 |
Re: I didnt think it would work.
You hooked the 12 volt gun to your 6 volt battery and it worked?
Interesting. I always grab a 12 volt battery from my garden tractor for this purpose. Less work if I can hook it to the 6 volt battery. |
07-29-2016, 06:34 AM | #3 |
Yes, it worked on the FS Distributor for adjustment, I took off the stock distributor.
07-29-2016, 07:32 AM | #4 |
Yup it'll work, the light just won't be as bright.
Cowtown A's |
07-29-2016, 12:31 PM | #5 |
lite don't know the difference
V4f |
07-29-2016, 03:48 PM | #6 |
07-30-2016, 10:58 AM | #7 |
Voltage is a akin to pressure difference from two different points, Amperes is akin the the amount of flow of electricity. so yes it would work but with less pressure if you will.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
