Old 07-06-2016, 09:07 PM   #1
1929
Default Electric Fuel Pump and Regulator?
Can anyone recommend a good Fuel pump and Regulator for a downdraft Stromberg?
1929 is offline   Reply With Quote
Old 07-07-2016, 12:10 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Electric Fuel Pump and Regulator?
I have 2 Holley 12 volt pumps that deliver the correct pressure and volume when I run them on 5 volts in my 1950 Studebaker.
Carter is also another good brand, and I have a 6 volt Carter, which is also a rotary pump with all metal parts.
Old 07-07-2016, 06:14 AM   #3
Phred
Phred's Avatar
If you are running 12 volts, the Facet cube pump works well and does not nee a regulator.
I think I am running the #40163 with my single Stromberg 97. Pump is mounted on the chassis rail.
See http://www.facet-purolator.com/cube-fuel-pumps.php
Phred is offline   Reply With Quote
Old 07-07-2016, 06:18 AM   #4
1929
I have a 6 volt system.
Old 07-07-2016, 07:22 AM   #5
Tom Wesenberg
Remember, these pumps call for a filter BEFORE the pump intake.
Old 07-07-2016, 08:09 AM   #6
denis4x4
denis4x4's Avatar
Use a Holley fuel regulator with a gauge. Fuel pumps that are supposedly preset at a certain pressure usually aren't. When installing an electric fuel pump (6v or 12v) be sure and include a switch somewhere so that the pump can be turned off when you are doing engine tune ups.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 07-07-2016, 11:21 AM   #7
ursus
Why not run a 12-volt pump on your 6-volt system? This way you may not need the regulator.
ursus is offline   Reply With Quote
Old 07-08-2016, 02:58 AM   #8
Miles in MN
Miles in MN's Avatar
I am using an Airtex fuel pump and Holley regulator to feed dual downdraft carbs on a hopped-up Model A. The Airtex pump is available for six-volt positive ground as part number E8902 which will deliver 80 gallons per hour at 2.5-4 PSI. The pumps are available from Airtex online. The Holley regulator will regulate pressures down to 1-4 PSI which covers the recommended fuel pressure for your Stromberg carb. The regulator is available from Summit Racing as part number HLY-12-804 for just under $30.00. The regulator has multiple outlet ports so it is easy to include a fuel pressure gauge with your installation. My Airtex pump is fairly new but seems to be working well; I replaced a Holley pump of higher capacity that was quite noisy. The regulator has been doing its job since 2009 with no problems. Hope this info helps.
Miles in MN is offline   Reply With Quote
