05-23-2014, 12:58 PM | #1 |
Rear Axle Seal in Bell
Anyone have any seggestions as to how to replace the axle seal in the end of the bell. I was thinking of using the axle to slide the seal in place then use a piece of tubing slightly smaller to the seal to drive it in.
05-23-2014, 01:56 PM | #2 |
Re: Rear Axle Seal in Bell
Do you have the old seals out of the axle housing bells yet? To me, that was more difficult than putting the new seals in place. I can take some pics of the tools I made to remove and replace these seals and post them here. They are nothing fancy, but they get the job done.
05-23-2014, 02:14 PM | #3 |
Bratton's Model A place (A has same seal) sells a nifty and cheap ($7) tool that you just screw onto a length of pipe...but if you look at it, you will probably get the idea that a fairly simple stack of washers or such on a threaded rod could be whipped up to do the job. Original KRW tool is just a long rod with a pointed end that slides into seal and a flange to drive it.
05-23-2014, 03:22 PM | #4 | |
05-23-2014, 03:23 PM | #5 | |
05-23-2014, 03:34 PM | #6 |
Reinstalling once you have a suitable tool is easier than it might look as the recess for the seal guides it into place. Seal is leather or rubber lip in a steel shell. |
05-23-2014, 04:14 PM | #7 | |
Thanks for your help. |
05-23-2014, 04:45 PM | #8 |
Good you finished lunch. Your hands will smell like a dead whale for about a week after messing with the 140 weight!
05-23-2014, 05:19 PM | #9 | |
Here are some pics of the tools that I use to remove and install those seals. The long screwdriver and piece of round stock are used to remove the seal. The tool used to insert the seals is a pusher plug machined from aluminum bar stock that's mounted to a piece of 1/2" dia. bar with a section of 1/2" all thread on the back of the bar when additional length is needed for putting that same seal in the front of the torque tube. I have two new seals in the pictures so you can see what they look like. hopefully pics will appear hear in a little while
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 05-23-2014 at 05:25 PM. |
05-23-2014, 11:29 PM | #10 |
John, thanks for the pics. I did get the old seals out with a long screw driver. They came out in 4-pieces. I decided to take the bells down and put them in the hot tank over night and will pic them up in the morning. I made up a seal driver out of a piece of 3/4" black iron pipe and a 1'X3/4" bell. The seal shell measures 1.834 and I sanded the bell down to 1.810 so it should work just fine. I will put the seal in place with the pipe and then use a piece of tubing to hold the seal in place and pull the pipe out then install the bell on the end of the pipe and drive the seal into place.
05-23-2014, 11:34 PM | #11 | |
05-23-2014, 11:35 PM | #12 |
I use a length of pic pipe to remove these seals. Didnt hammer on it - just kept kept sliding (driving) seal with it.
Don't mind learning from my mistakes. Just wish I didn't learn EVERYTHING from my mistakes.. |
05-23-2014, 11:36 PM | #13 |
05-24-2014, 05:55 AM | #14 | |
Note: to do the above, the outer diameter of the aluminum pusher plug (or whatever you use) must be small enough to pass through the seal locating flange that's inside the front of the torque tube.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 05-24-2014 at 06:10 AM. |
05-24-2014, 08:29 AM | #15 |
I meant "PVC" but I was thinking of the seal in the torque tube. Shouldn't read and reply late at night.
05-24-2014, 09:41 AM | #16 | |
Thread Tools | |
Display Modes | |
