05-21-2014, 10:21 PM | #1 |
Flathead Motor Oil
I did a search on this but could not find anything.
What motor oil would you guys recommend non-detergent or detergent? Also what about the zinc? |
05-21-2014, 10:31 PM | #2 |
Re: Flathead Motor Oil
I'll let some one else comment on det/non-det oil but I'd run a zinc oil or zinc additive in any flat tappet engine and renew every 3000 mi. For the $15 every 3000 mi for at least an additive, I won't take the chance.
05-21-2014, 10:53 PM | #3 | |
Here is a recent thread listed a week or so ago.... http://www.fordbarn.com/forum/showth...light=oil+zinc .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
05-21-2014, 11:30 PM | #4 |
I run the VR1 in my other cars so I am familar with the zink issue. My flathead does not have a filter so I guess my main concern is the non-detergent verses the detergent oil and using a detergent oil in a engine that has been run with non-detergent.
05-21-2014, 11:40 PM | #5 |
I've run Detergent oil in every flathead i've had, and been happy with it.
05-21-2014, 11:41 PM | #6 |
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
05-22-2014, 01:43 AM | #7 |
non detergent oils have nothing in then that is good for your engine, no rust inhibators, no acid neutralizes, no anti foaming ingredients, no zink and no nothing that is good, there is a reason all car makers stopped using it, and the reason is it does nothing to protect your engine
05-22-2014, 02:04 AM | #8 |
Nothing wrong with using detergent oil in an engine that's only had non detergent oil before, I used to think that it would be bad. That the detergent oil would free up the sludge and whip it around the engine. But it don't do that, it ain't ment to and can't do that. It only keeps the bits in suspension that come loose, for want of a better description, while the detergent oil was/is in use. It won't clean old sludge and stuff out of the pan. I've seen pics of a valve chamber on s flathead that used non detergent for years, then a switch to detergent oil years later, still has all the old (pre detergent) sludge in there.
Use good detergent oil. Martin. |
05-22-2014, 02:41 AM | #9 |
What about the seals?Non detergent,change every 1000 miles.
05-22-2014, 07:09 AM | #10 |
non detergent oil is good for air compressors,not flatheads.
John |
05-22-2014, 08:42 AM | #11 |
I recommend 10-30 detergent oil in an engine with an oil filter and non detergent oin in one with out. However I don't know where you could find any right now.
05-22-2014, 08:57 AM | #12 |
05-22-2014, 09:19 AM | #13 |
Detergent oil, absolutely.
05-22-2014, 09:32 AM | #14 |
Lanny.......I use "Classic Car Motor Oil" as advertized in the V-8 Times.......contains Zinc. Check it out at ClassicCarMotorOil.com or 317-225-0040.......thanks
05-22-2014, 09:50 AM | #15 |
Originally I ran 30wt detergent because that's what the previous owner used. Lately I've been using Shell Rotella 15w40 with zddp+ additive.
05-22-2014, 09:59 AM | #16 |
VR1 change the oil frequently!
05-22-2014, 10:38 AM | #17 |
Thanks Guys for the input. A friend just bought a 40' and he did a whole lot of reading about it and said what some of the others had said about the non-detergent oil was suppose to collect the sludge in the bottom of the pan and then the large drain was for the sludge to drain out. He also mentioned that if changing to detergent that the detergent would break loose the old sludge and could possibly ruin the engine. This was my concern.
05-22-2014, 11:08 AM | #18 |
Rotella T 15W40 plus a bottle of STP
05-22-2014, 02:25 PM | #19 |
Detergent and either 10W-30 or 10W-40.
05-22-2014, 02:59 PM | #20 |
Never seen any evidenced to support the "it will break loose the old sludge" that ain't what it does. I think you'll find the folk that believe this, also know that a Stewart Warner southwind heater will burn your car into a fireball, cus gas is injected into the heater. Or they crack and everybody in the car dies from monoxide poisoning.
Martin. |
