Old 05-05-2014, 11:12 AM   #1
white64
white64's Avatar
Default Steering issue
My model A has an all Ford front suspension:
  • '40 wishbones un-split w/ model a wishbone yoke
  • '46 spindles
  • '46 brakes
  • '46 shocks
  • model a axle
  • f1 steering box w '46 passenger car gears
  • 1935 Ford wire wheels
  • denman 6.50 tires with tubes
But when I hit a rut that travels along the road, you'd better be paying attention because it will reach out and grab the front end and who knows what side of the rut you'll come out on!
The tie rod ends are all new, the caster is set at 7 degrees, the toe-in is at 1/8 inch, the play at the top of the '46 stock (16 inch?) steering wheel is about 1 1/2inches ( my motor manual from 1946 says 3 inches is acceptable, whoa Nellie!), the end play on the steering shaft itself is negligible...
I cannot move the steering arm by trying to pull it front to back when checking for play...
What am I missing?
white64 is offline   Reply With Quote
Old 05-05-2014, 12:08 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Steering issue
Does the wishbone yoke have a rubber ball on it?? Also ck for tightness of the ball. Ck the kingpins for wear, ck for loose brake backing plates, Ck the balls on the steering arms, ck tire pressure and age of tires. Hope this helps.
Paul in CT
Old 05-05-2014, 01:40 PM   #3
white64
white64's Avatar
Thanks Paul,
it has a '46 ball socket, with a '46 rubber ball w/2 socket shims... it was a very tight fit. The king pins are newly installed... tires are new, running 32 lbs of air
maybe this rut issue is common? maybe...?
Old 05-05-2014, 05:51 PM   #4
Tom Walker
Tom Walker's Avatar
Fit the DIY Panhard Bar and all yr prayers will be answered.
Tom Walker is offline   Reply With Quote
