05-04-2014, 09:19 PM | #1 |
Clutch pedal adjustment
I need to press my clutch pedal almost to the floor to disengage the gears and shift. Is there an adjustment to raise the pedal height?
05-04-2014, 09:28 PM | #2 |
Re: Clutch pedal adjustment
Adjust your pedal to have about 1 inch free play. If properly adjusted then you will need to adjust your pressure plate finger heights
05-04-2014, 10:01 PM | #3 |
Yes, pull the cotter and pin on the adjustment rod at the bottom of the clutch pedal. Then you can screw the rod in or out of the trunion.
05-04-2014, 10:09 PM | #4 |
Be advised that you will need a hydraulic jack to re-attach the trunion.
05-05-2014, 07:48 AM | #5 |
I just push them up with my hand/fingers. A stilson or pipe wrench will aid you best if you need a little more leverage. I know the suppliers ( snyders/brattons) are now handling a clutch arm lever to help with this.. but in my opinion it is not needed.
Larry |
05-05-2014, 10:20 AM | #6 |
05-05-2014, 11:08 AM | #7 |
I hook a gungee cord to the clutch pedal to hold it up while I repin the linkage.
Thread Tools | |
Display Modes | |
