05-04-2014, 01:59 AM | #21 |
Re: setting head stud height?
I'm using ARP studs and they have an allen socket in the top of the stud so that you can: 1) insert/remove studs, 2) keep them from turning when applying torque to the nuts.
Came in real handy when I had to remove a stud to fix a leaky one today.
05-04-2014, 03:06 AM | #22 |
A little off topic but what do you chase the threads with? A regular tap or a flat bottom one? (is there such a thing?)
I’m worried that the stud might bottom out if any junk is still in the hole and will leave the stud higher rather than lower... Has that been a problem? I am just about to put in new studs and a high compression head. |
05-04-2014, 07:34 AM | #23 |
Flat bottom tap. There is such a thing.
05-04-2014, 01:29 PM | #24 |
Rather than use a bottoming tap, I would cut an X in a bolt and use that to clean the threads.
05-04-2014, 09:01 PM | #25 |
great ideas,, thanks
05-04-2014, 09:31 PM | #26 |
05-04-2014, 09:31 PM | #27 |
I would use a thread chaser not a tap. You want to be careful you don't cut the threaded holes oversized
05-04-2014, 09:55 PM | #28 |
If you have the same class tap (typcially 2b) the threads really can't get oversized. A problem can arise of the threads are damaged. If you have damaged threads then more material could be removed. The threads may not be oversized when checked with a thread gage but they could be missing material making the threads weaker. A tap cleans threads very well and used correctly they won't cause damage. The idea of the chaser is that they can form and cut damaged material that makes up a thread back into place. They don't fix cast threads very well but they may clean them ok. I've never used one since I have a tap set but a set of chasers is much cheaper.
05-04-2014, 10:02 PM | #29 | |
05-04-2014, 10:41 PM | #30 |
Dog here,
Wull, we got more important things to wurry about, than if ALL our threaded studs stick up jist right, above the NUT! Ol' Gregg, (RIP) even put thet looong stud in the rong hole---BUT, Ol' Bill's got thet covered, he bought 10 CHROME acorn nut covers!! "Why 10? it only has 9, (count them) studs"?----"In case we drop 1 down the bellhousing,DUMMY"! Ol' Bill sez if he ever has to take the head off, he's gonna' git sum REAL acorn nuts & copper plate them & tell folks it's a Model "T" motor!! Ol' Bill's a RASCAL, but he loves me!! He wanted to take me to the car show today, BUT I couldn't fit in the scooter basket---Buster T.
05-05-2014, 06:04 AM | #31 |
Bill we are just trying to do the job correctly so we do not have to do it again!!
Mike |
05-05-2014, 06:54 AM | #32 |
He's just having fun with you!
05-05-2014, 07:42 AM | #33 |
