Old 07-28-2016, 07:53 PM   #1
1929
Default I didnt think it would work.
I didn't think my 12 volt timing gun would work on my 6 volt car, but it did, so the car has perfect timing and is running very well.
1929 is offline   Reply With Quote
Old 07-28-2016, 10:08 PM   #2
bunnyc
bunnyc's Avatar
Default Re: I didnt think it would work.
You hooked the 12 volt gun to your 6 volt battery and it worked?
Interesting. I always grab a 12 volt battery from my garden tractor for this purpose.
Less work if I can hook it to the 6 volt battery.
bunnyc is offline   Reply With Quote
Old 07-29-2016, 06:34 AM   #3
1929
Yes, it worked on the FS Distributor for adjustment, I took off the stock distributor.
Old 07-29-2016, 07:32 AM   #4
Logan
Logan's Avatar
Yup it'll work, the light just won't be as bright.
Cowtown A's
Logan is offline   Reply With Quote
Old 07-29-2016, 12:31 PM   #5
V4F
V4F's Avatar
lite don't know the difference
V4f
V4F is offline   Reply With Quote
Old 07-29-2016, 03:48 PM   #6
Bruce_MO
What worked for me was to use a 12 volt battery charger, with the positive lead connected to ground on the car, and the negative lead of the charger connected to the negative lead of the strobe lite. The positive lead of the strobe grounded to the car. Not sure why it worked , but it did, and it would not work purely as a 6 volt power source
Bruce_MO is offline   Reply With Quote
Old 07-30-2016, 10:58 AM   #7
mshmodela
mshmodela's Avatar
Voltage is a akin to pressure difference from two different points, Amperes is akin the the amount of flow of electricity. so yes it would work but with less pressure if you will.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
