05-26-2016, 05:49 AM | #1 |
Throttle Balls?
Who sells throttle balls, not throttle joints or Holley Balls which are short on the thread, need about 3/4 of an inch thread with a ball end that will fit in the throttle rod.
05-26-2016, 06:35 AM | #4 |
Re: Throttle Balls?
Try McMaster Carr
05-26-2016, 07:21 AM | #5 |
Re: Throttle Balls?
05-26-2016, 08:46 AM | #6 |
Re: Throttle Balls?
05-26-2016, 09:03 AM | #7 |
Re: Throttle Balls?
Whut ur "BALLS"??---Buster T.
05-26-2016, 09:49 AM | #8 |
Re: Throttle Balls?
Chuck in the Swap meet section is selling throttle assemblies, on page 4 right now. You could get an original one from him and then cut it off however you want.
05-26-2016, 05:19 PM | #9 | |
Re: Throttle Balls?
05-26-2016, 05:22 PM | #10 |
Re: Throttle Balls?
Google "Throttle Linkage" There are quite a few out there. (Even on eBay)
05-26-2016, 05:27 PM | #11 |
Re: Throttle Balls?
05-26-2016, 06:56 PM | #12 |
Re: Throttle Balls?
How about if you cut off the thread, drill and tap the ball, insert a longer threaded rod or use a bolt.
05-26-2016, 09:14 PM | #13 |
Re: Throttle Balls?
Check out cabinet hardware, as I've seen ball headed screws used on doors.
05-26-2016, 10:42 PM | #14 |
Re: Throttle Balls?
Any of the speed shop parts catalogs have a variety of them.
Bob from Northport Northport, Michigan |
05-26-2016, 10:51 PM | #15 |
Re: Throttle Balls?
Speedway, Jegs, Summit, The Hot Rod Company are just a few of the places you can get they for a couple of bucks each.
05-27-2016, 08:57 AM | #16 |
Re: Throttle Balls?
Start with the 7/16 long piece from the vendor, add a 10-32 coupling nut, about 3/4 long, and another piece of 10-32 thread rod from a screw or bolt. You can use lock nuts, red locktite, or JB to hold the assembly together. If necessary the coupling nut can be shortened. You need 5 threads engagement on a 10-32 for full strength, just 5/32 of an inch.
