06-04-2020, 04:50 PM | #1 |
Is there a hydraulic throwout bearing for a 3 speed transmission
Is there a hydraulic throwout bearing that will fit a model A 3 speed transmission.
I'm building a Doodlebug with a John Deere LA tractor engine and the LA clutch arm just doesn't seem beefy enough to me and its a bear to actuate. I've looked and can't find a 1-3/4" I.D. hydraulic throwout bearing. Looking for ideas. Bruce |
06-04-2020, 05:41 PM | #2 |
Re: Is there a hydraulic throwout bearing for a 3 speed transmission
Lengthen the lever!
06-05-2020, 06:00 AM | #3 |
Adding a hydraulic cylinder and master cylinder should be doable. Take some measurements and head to the local dismantling yard.
06-05-2020, 07:44 AM | #4 |
It wouldn't be hard to lash up a master and slave hydraulic clutch control if you are handy..plenty of 'donor' cars and trucks outhere that use them
06-05-2020, 09:32 AM | #5 |
The doodle bugs I've seen with JD engines usually used the LUC drive set up from the pull behind combine. It's the same basic engine as the LA but a different drive. It seems to me that it's a small three spring clutch. It should be easier to actuate.
Hydraulic clutch actuators are out there but I don't remember what the input retainer sleeve diameter is. The Ford stuff had some pretty big ones and a lot of the later stuff is less than 1.375". |
06-05-2020, 11:06 AM | #6 |
06-05-2020, 01:10 PM | #7 |
[QUOTE=Patrick L.;1895716]I have no idea what a hydraulic T/O bearing is,
I have no idea what a hydraulic T/O bearing is either. Can someone explain. |
06-05-2020, 02:09 PM | #8 | |
[QUOTE=wmws;1895863]
Ruth "Sometimes you really DO need to read the whole thread" |
06-05-2020, 02:15 PM | #9 |
Be sure to ask this on HAMB.
Charlie Stephens |
06-05-2020, 06:32 PM | #10 | |
[QUOTE=Ruth;1895882]
06-06-2020, 02:19 PM | #11 |
They generally come with shims to adjust the throw.
06-06-2020, 04:58 PM | #12 |
Is it used for a smoother/easier push down?
06-07-2020, 11:09 AM | #13 |
They are often used where space is limited, such as in race cars.
06-15-2020, 11:06 AM | #14 |
Well I've searched the net and checked Speedway and a few others and all I can find is hydraulic throwout bearings with an 1.375" ID, if anybody knows of one with a 1.75" ID I certainly would appreciate your input.
Bruce |
06-15-2020, 01:08 PM | #15 |
Modify the LA arm, make a brkt for a hyd slave cyl and add a M/cyl. Innovate.
Paul in CT |
