Old 02-19-2013, 04:45 PM   #21
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: 1929 Ford AA with 3 sticky intake valves! What's the best solution?
Is it possible to add valve spring spacer washers above the springs to increase spring pressure when you have some sticking valve problems? This could also help eliminate floating valves at higher RPM's. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 02-19-2013, 08:34 PM   #22
txturbo
txturbo's Avatar
Once you get it running put some MMO in the gas and oil.
txturbo is offline   Reply With Quote
