Old 03-23-2024, 07:09 PM   #1
rmengines
Default 1932 Ford Stamped Steel Frame NOS
City: Columbia City
State: IN
Price: 3900.00
This is a 1932 Ford Frame. The rails are stamped steel and have never been completely assembled. The front axle is an OEM Ford heavy 1932 that was dropped 4 inches many years ago. It has 1937 round spindles with new king pins. The front spring and all mounting hardware is Speedway. The wishbone was split with threaded bungs installed. The front crossmember is NOS original Ford style. The rear crossmember is 1939 OEM Ford that has been flattened. The front and rear spreader bars are new. It comes with a 1936 Ford rear axle with hydraulic brakes and an open drive shaft conversion. It also comes with the front hydraulic brakes. I also have a rear spring and the 1936 rear radius rods. The frame is just mocked up and will need final assembly. This is a great start for a vintage hot rod. $3900.00 260 438-1724
rmengines is offline   Reply With Quote
