Old 12-18-2022, 07:18 PM   #1
Itchy-Pit
Itchy-Pit's Avatar
Default Help ID these Model A Radiators?
Late 30-31 yes?
Itchy-Pit is offline   Reply With Quote
Old 12-18-2022, 08:14 PM   #2
Ramman
Default Re: Help ID these Model A Radiators?
Height dimensions?
Threaded or 1/4 turn filler neck?
Ramman is offline   Reply With Quote
Old 12-18-2022, 08:18 PM   #3
Itchy-Pit
Itchy-Pit's Avatar
That one quarter turn and I have another which is threaded and shorter
Old 12-18-2022, 08:34 PM   #4
Mike Peters
Mike Peters's Avatar
Basically, the taller Model A radiators with the modern twist off caps are 30-31. The shorter versions with the fine threaded caps are 28-29.
Mike Peters is offline   Reply With Quote
Old 12-18-2022, 08:35 PM   #5
Itchy-Pit
Itchy-Pit's Avatar
Thx Mike
Old 12-18-2022, 09:01 PM   #6
Joe K
Joe K's Avatar
The shorter radiators are distinguished further by being "Funnel top" or "straight tube" with the funnel tops being the earlier feature replaced by the straight tube in production. Most funnel tops you see are "original" as I don't believe anyone has reproduced them until the current "Brass Works" repop.
A shroud on the funnel top is an indication of an "earlier" radiator.
Joe K
Shudda kept the horse.
