Old 01-11-2011, 08:50 AM   #1
jnunez1955
Default Model A steering wheels
im using the stock steering column(light controls are on the dash), but i want to use a different steering wheel because mine is all beaten up.
what steering wheels will fit the stock model a column?
can a f1 fit?
jnunez1955 is offline   Reply With Quote
Old 01-11-2011, 08:55 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Model A steering wheels
What's an f1?
My 31 had a banjo wheel from about 1937 when I bought the car, but I removed it and installed the correct wheel.
Old 01-11-2011, 10:01 AM   #3
jnunez1955
i found a couple of good deals online
an 1948 f1 steering wheel
and a 1949 mercury steering wheel
i was wondering if one or the two will fit.
Old 01-11-2011, 10:06 AM   #4
Kirby1374
Kirby1374's Avatar
Originally Posted by Tom Wesenberg View Post
What's an f1?
F1 48-52 Ford 1/2 ton truck
Kirby1374 is offline   Reply With Quote
Old 01-11-2011, 12:25 PM   #5
Tom Wesenberg
OK, thanks, I figured it must be some Ford pickup, but didn't know the time period. The only Ford pickup I ever owned was one from the 60's and it sucked gas so bad I sold it shortly after I got it.
Old 01-11-2011, 04:47 PM   #6
jnunez1955
so do any of you know if a 1949 mercury or a 1949 ford f1 steering wheel will fit properly on the column?
