Old 03-28-2013, 06:20 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default Flywheel question
I am wanting to go to a lighter flywheel with a V-8 clutch. Would I be better off modifying my A flywheel or adapting a V-8 flywheel?
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 03-28-2013, 06:36 PM   #2
Duffy1
Default Re: Flywheel question
Lots of info on this . If you will do search you should find it . Use your A flywheel .
Duffy1 is offline   Reply With Quote
Old 03-28-2013, 07:03 PM   #3
just plain bill
just plain bill's Avatar
V8 flywheel requires starter drive modifications, reversing the starter drive and installing an outboard bearing on the shaft. A lightened stock flywheel is much easier to deal with. I use a V8 flywheel on my modified roadster and have done this modification a few times. I don't think it would be worth the hassle except for competition use. If an "off the shelf" starter could be found then it would be a different story.
just plain bill is offline   Reply With Quote
Old 03-28-2013, 08:58 PM   #4
Milton
Milton's Avatar
Use the A flywheel. Modifications are a pain in the A.
Milton is offline   Reply With Quote
Old 03-28-2013, 10:35 PM   #5
Chris Haynes
Does anybody in the Los Angeles area do the flywheel modification at a reasonable price?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 03-29-2013, 05:02 AM   #6
James Rogers
James Rogers's Avatar
I am not in LA but I have shipped several to that area. I can do any weight you want. I don't post prices here but you can call or check out my web site for info. The phone number is on the web page.
http://www.model-a-ford-4bangers.com/
Old 03-29-2013, 09:36 AM   #7
nick c
Chris, you might want to get a copy of Secrets magazine January 2006, page 6 & 7, it has the drawing. There is one misprint on the drawing that was noted in the April 2006 page 35, the dimention 5.735R is actually 5.312R. The April 2006 issue of Secrets has info on the V-8 flywheel pages 14, 15 and 16. I did one 63 lb. model A flywheel on my lathe and turned it down to 36 lb. acording to the drawing.
Good luck, carry on the good work Chris.
nick c
nick c is offline   Reply With Quote
Old 03-29-2013, 11:59 AM   #8
V4F
V4F's Avatar
lighten the stock flywheel & have it redrilled for the v8 pressure plate . i had 20# off mine & balanced & redrilled for the v8 clutch . works fine .
V4f
V4F is offline   Reply With Quote
Old 03-29-2013, 12:17 PM   #9
Chris Haynes
nick c
Nick,
I don't have a lathe nor do I know anyone with one big enough to handle a flywheel.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 03-29-2013, 12:19 PM   #10
Chris Haynes
He is geographically undesirable.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 03-29-2013, 12:40 PM   #11
Crazydaddyo
Crazydaddyo's Avatar
Taylor engine will lighten your A flywheel.
Call Chris at 562-698-7231
Crazydaddyo is offline   Reply With Quote
Old 03-29-2013, 01:49 PM   #12
gwhite
gwhite's Avatar
I just had James lighten one up for me a couple weeks ago...drilled for the V8 pressure plate & lightened down to about 36lbs.
gwhite is offline   Reply With Quote
Old 03-29-2013, 03:32 PM   #13
gwhite
gwhite's Avatar
See post #6
Old 03-29-2013, 03:37 PM   #14
Chris Haynes
Taylor wants $275.00 to do the job. H&H wants $450.00. Guess who is getting the job?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 03-29-2013, 06:33 PM   #15
James Rogers
I get 425+ shipping for the whole shebang, flywheel, clutch,pressure plate, with new starter ring. probably be 50$ shipping.
Old 03-29-2013, 06:35 PM   #16
CarlG
CarlG's Avatar
You usually get what you pay for!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-30-2013, 04:25 PM   #17
taylorengines
Remember that is for labor only ! The Clutch kit and ring gear are extra ! So H&H More than likely is in the ball park, I would imagine everyone on here thats offering up there service is more than qualified, Come see me if i can help, Im super busy but can find time to help out. Good luck
taylorengines is offline   Reply With Quote
