Old 03-22-2011, 10:04 PM   #1
Slick Willy
Slick Willy's Avatar
Default A couple of quick 21 stud aluminum head questions
Im waiting on the graph-tite gaskets I ordered and now got a few final things I need to make sure of...
Im putting on a set of 21 stud aluminum replacement heads so...
What should I use for a gasket tackifier? Should I use the copper spray or nothing, grease them or not?
and..any thoughts (not arguments, fellas!) about torquing specs and sequences?
Im really hoping this thing will run again!!
Slick Willy is offline   Reply With Quote
Old 03-23-2011, 05:14 AM   #2
Barry WNY
Default Re: A couple of quick 21 stud aluminum head questions
I used a "good ol boy" recommendation to spray with aluminum paint, racers pulled their heads so often,gaskets could be re-used, worked for me. I also used a micro-bead of red silicone around studs for insurance and rounded up enough stainless washers.
Barry WNY is offline   Reply With Quote
