10-10-2019, 07:17 PM | #21 |
Re: Pulling rear hub and axle shaft assembly on 50 woodie
I can usually figure this stuff out quickly. my restoration is stalled until i pull these shafts. Beat the crap out of them again after spraying more penetrating oil. nothing. I'm getting pissed.
10-10-2019, 07:49 PM | #22 |
I've had good luck hitting the axle with a 3lb hammer on the center, most of the time it will jump out. I've had to use a chain on two studs and a winch to put pressure on the axle and the strike the side of the axle with the hammer, the vibration seems to be what works.
Greg |
10-10-2019, 11:17 PM | #23 | |
Another place where oxy/acetylene can be your friend. |
