Old 06-19-2015, 10:22 AM   #1
d.j. moordigian
d.j. moordigian's Avatar
Default New Tires,...and storage off the car..
I bought 6 new Goodyear's mounted on powder coated wheels, which are
the wrong color, not BLACK. The problem is storage, ...my car is not ready
for the wheels / tires, and "NO", I not lending them too anyone!
The questions...
1. Do I leave them mounted(harder to store), off the ground. Will the tires
come off the rims easily in say 2 years?
2. Take them off now and store them in "bags"?
3. The new tubes,...store them in bags also,...with some air in them?
Thanks, Dudley
d.j. moordigian is offline   Reply With Quote
Old 06-19-2015, 10:30 AM   #2
BlueSunoco
Default Re: New Tires,...and storage off the car..
d.j. do you mean whitewalls? In that case don't stack them on top of each other directly, the whitewalls will turn brown.
I'd think the best way to store them would be to leave them mounted, keep them in a cool spot out of sunlight, and set them vertically. Rig up a 2X4 framing bolted to the studs on a garage wall perhaps. I suppose for overkill, swab them down with silicone and bag each one in a large brown paper bag like people use for leaf collection.
If you need to repaint the rims, then I'd probably go ahead and take the tires off now and store them the same way.
Good luck a set of six Goodyears ain't cheap
BlueSunoco is offline   Reply With Quote
Old 06-19-2015, 11:40 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I bought a set of 5 new whitewall Goodyears mounted on red painted 19" rims, about 12 years ago. They will look good on my black 31 Town Sedan. I've had them stored, as I bought them, in my garage. If they were off the rims, then I'd put the inner tubes inside the tires and air them up just enough to fill the tire shape. Again, a cool dark space. I have a set of 21" like this in my basement.
Old 06-24-2015, 11:13 AM   #4
d.j. moordigian
Okay,...thanks for the advice ! They are Black wall...
I decided to remove the tires from the rims for storage. They have new tubes, marked
"radial" on the stems(forgot to look at who made them). They also have "flaps", not
the usual "band" too protect the tube,...whoa, the flaps are about $28 each!
The flaps got me thinking about the metal stems and the bridge washer. Would the
correct order, with flaps, be,....tube, metal stem, flap, bridge washer then the nut?
The flaps are quite thick!
Dudley
Old 06-24-2015, 12:20 PM   #5
Tom Wesenberg
I've used truck flaps for AA wheels, but I didn't know flaps would even fit an A wheel.
Old 06-24-2015, 05:00 PM   #6
d.j. moordigian
Tom,...Snyder's have them in there 2015 catalog, page A-97,....they don't
show-up on there "on line' catalog..
The flap itself is quite stiff, I had to work hard too get the tire dismounted.
Sure makes it hard to get the tire to drop in the center of the rim..
Old 06-24-2015, 05:27 PM   #7
CarlG
CarlG's Avatar
Snyder's on-line catalog:
• A-1025-AR for 21" wheels
• A-1025-BR for 19" wheels
• A-1025-CR for Truck 20" wheels
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-24-2015, 07:21 PM   #8
d.j. moordigian
Yep Carl.....I missed it!
I was looking in the "Tire section",....should have looked in the "Wheel section"..
Old 06-24-2015, 08:50 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
My tires are stored ON THE CAR. James just hung me 2 knotted ropes, so I can get in the car & put the dash together & VROOOOM!
Limpy Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-25-2015, 07:21 PM   #10
d.j. moordigian
Limpy Bill W.
I wish my car was close enough to store them there! And it's about time your
back on the road!!
Old 06-26-2015, 09:32 AM   #11
BILL WILLIAMSON
back on the road!!
Dudley, my true blue friend,
THANK YOU for the encouragement, it's the sh*ts, learnin' to walk again.
Willy Bill
