07-06-2013, 07:07 AM | #1 |
Model A , B U joints
Are the U joints in these cars meant to have anything to prevent lateral play in them (side top side). I don't see any C clips in them like a modern joint. If not, what keeps them running true, without vibration.
Thanks Al |
07-06-2013, 07:08 AM | #2 |
Re: Model A , B U joints
Should be "side to side" not "side top side"
07-06-2013, 08:11 AM | #3 |
The driveshaft is supported by a bearing, the side to side play is needed to allow for slight differences in alighnment.
07-06-2013, 02:06 PM | #4 |
If you use the late 31-48 U-joint they use the clips to hold thr hard steel bushings in place.If the original style A U joint is good,then no need to change it.As long as the U-joint hsg is packed with thinner winter grade standard chassis grease & the fitting given about10 pumps of grease every 1,000 miles,then the U-joint will outlast the owner even if he is young now.
07-06-2013, 02:34 PM | #5 |
Additional (to Kurts answer):
Bearings in the U joint have to be TIGHT . If you hold the u-joint in your hands and you can easily move it and it does noises while you shake it, ITS GONE. Rivetet (early version) are junk than, later version is to be repaired. I suggest to repair an original rather than buy a complete new one.... If in doubt repair it, as its no fun to take the axle out a 2nd time. (bin there... done that...) Have fun Christoph @ ericr Thank you so much for your help Last edited by Christoph; 07-06-2013 at 02:57 PM. |
07-06-2013, 09:56 PM | #6 |
07-06-2013, 10:42 PM | #7 |
I've still got some of the late style U joints that I have used since I was a boy and i'll be 67 this year. I've never bought a new one.
